there was a blanket ban on them, for a while but they are starting to get wise, we were in talks with some-one who does drone following for arc as a friend of a committee member, he has all permits, but could not work out dates.
Am hoping now that things like rally V*'s and such use them that it becomes more frequent and easier to get. same as drone licencing from CASA is getting progressively easier.
3 hours ago, UNR33L said:
usually I use my motorbike Helmet & gopro mount works well get to see what the driver is looking at cones / direction etc.
Has anyone tried mounting the gopro right in front outside the mouth part?
thats exactly what I do, and its by far the best position.
basically this (not mine but similar setup):
  • Like 1
Why not dash cam it? Even using a shitty ass $80 dash cam from 8-10 years ago picked up pretty good view and sound for me. I would think anything modern be very good quality and bonus you can just leave it installed and use as a dash cam...
whilst the res of those is great the ones I've seen have been fairly slow FPS (prob for space) where as the dedicated ones are much better. (not looked for a while however)
will install one in next car, think I could do a whole dash cams aust streams just from my 1 a week trip to work
HUme hwy brings out the worst in people
There was a really good dash cam a couple years back, pretty exxy but it was made for racing - had awesome quality video and GPS logging for lap timing with 10mhz(?) signal.
6 hours ago, Birds said:
next moment car gets broken into to steal dash cam....
I remember having detachable face stereos worth less than a decent set up dash cam, or mobile phones that every-one was scared to leave in a car.
now throwing man $$ to something very obvious to outside folks.
  • Like 1
Some of them remove pretty easily with their shoe mount, I wouldn't want to have to screw it off every time
Yeah that's a bit of a worry, $500 item sitting in plain sight, who can be stuffed removing it every time.
Those Sony XPLODE head units were the bomb, all dem bright red LEDs before RGB came into play.. the double dinn Pioneer head units were for the rich kids
Edited by UNR33L
  • Like 1
Saw late 80's hilux on city link this morning, dints and rust on every single panel. Removed rear light globes so only the brake lights work. No lights illuminating the personalised and unreadable numberplate. Full dodgy, escaping tolls and speed cameras.
Has primo quality dash cam hooked up and iphone holder for maps. Car was a wreck, maybe waiting for perfect insurance claim.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
