So I picked up a used set of wheels, Rays Gram Lights 18x7.5 +47 with 245s all round for a good price but I'm having fitment issues. Tire clearance is perfectly fine but actually fitting the wheels on isn't.
To my knowledge the stud pattern is 5x114.3 so the rears fit fine apart from my lug nuts which don't seem to fit or lock, correct me if I'm wrong but we can't use OEM nuts and the thread pattern is 12x1.25? And I got the Rays Dura Aluminium for like $50, probably replicas but I don't mind (unless that's the reason they won't lock on properly).
The front rotors have this extra half stud thing, did a bit of research and it looks like it's in the place of the rotor lock down nut, the rear rotors have a flat bolt/screw that is flat on the plate whereas the fronts in the same area is protruding outwards.
Just wondering if you guys have any solutions before I hassle my mechanic with changing my tires...
Cheers guys
https://www.sau.com.au/forums/topic/458552-problem-fitting-aftermarket-wheels/
Take some pics of the rotor hats and studs to help us help you. And yep I reckon the issue is with the cheap knock off lug nuts you bought. I have used cheap ones before on my first car and never again they stripped the threads as they are weak and the thread pitch is not correct and off centre, which lead to loosing a rear wheel around a corner!! Not fun stay away from cheap lug nuts mate as I learned they literally have your life riding on them
Why on earth would you buy such evil offset wheels? The rears will actually sit another 6mm further inside the guards than even stock wheels :yucky: . People normally put on wheels with 50mm wider track to give the car some stance - not actually fit worse offset wheels. These will look beyond shit, I am sorry to tell you. I would be checking your strut clearance, especially on the rear - I wouldn't be surprised if they are hitting, and that is what is causing your fitment issues.
  • Like 1
Not really going for the stance look, if I wanted I could just run some spacers maybe but they're my first non OEM wheels for cheap so I'm not fussed. Fronts are +45 and rears are +50, so I assumed +47 would be suitable in the middle of the two.
I'll give it another shot tonight with some more tools (and sleep) and take some pictures.
Any recommended lug nut brands? Not looking to fork out huge amounts of money but a reliable and decent looking set would be nice. And also would it better to be open ended or close ended?
get fussed, its more important that you realise, it will look arse, track worse and be less safe than stock aswell as illegal.
im not the nanny police when it comes to wheels but your actively taking a step backwards for no viable reason.
So after further research, the half nut out front is just a dummy nut removable with the right tools and effort.
And I've decided to run 20mm bolt on spacers all round, would that make the fitment 'decent'?
You'll be fine. Just make sure the spacers are done properly and redone after driving a few hundred kms.
I run 25mm front and 20mm rear with OEM wheels. Yes they are probably illegal but most mods are illegal unless you get a certificate.
  • Like 1
which brand spacers did you get?
Spacers are illegal in Australia.
everything fun is illegal in Australia.
If you have an accident and they realise you have spacers on (which they WILL) your insurer will not pay you a single cent, as you have contravened all laws by running spacers. Plenty of people do it, but be warned.
Just buy the correct offset wheels and be done with it.
H&R trak+ drm
Yes please be aware it is illegal and insurers can try screwing you over for using them.
I am just sharing what I use and it is for me personally and whatever you take out of it is your responsibility and i will not be responsible for anything that happens.
Update:
I've fitted the wheels and nuts and it looks okay...bit tucked in so I'll be going with the 25mm spacers from gktech
At first the fronts were making a strange noise but I tightened the nuts and it was all good but the rears eventually made a rubbing, squeaking noise every time I braked, checked the rotors and it seemed something on the pad was somehow scratching the rotor, brought to the mechanic right around the corner because I my normal mechanic was booked out till next week and the guy said it just needed to be machined again as it was done properly, so I just let him do his thing to get it over and done with. Picked it up the next morning, the guy said he fit a smaller spacer (wot? didn't realise there was a spacer) to fix the noise but there was some noise still evident but he just said it just needed to be bedded in so off I went and with more driving the noise got louder so now I'll be leaving it on Monday to see what the issue is.
And before I went to the mechanic, I put my stock rears back on and the same sound could be heard so it wouldn't be the wheels.
Here's a pic
Edited by mkn23
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
