OK I appreciate your difficulties in getting to the tuner but rest assured cam timing can make 100hp difference in some cases. Tuning is not just about timing. There are half a dozen or more variables and the tuner has to change one at a at a time so that he knows what is making a difference and then change another variable which may affect the first etc. .. hence the many hours involved. If you know a good tuner can you not drive down at 4.30am give him the car for a day (say a Friday) and get him to check the cold start on Saturday morning and then drive home? Whatever it takes it has to be done properly.
Problem being I don't. The last two have been a waste of time and money.
Think I will give the local bloke a go. He is all good, just that there aren't many GT-R's around here and I wanted to short cut the learning process by having someone who has done 100 of them do the job.
Cold start is about the only thing that is fine. So a win there.
Hope not and hope so at the same time. May just be the cam gear bolts have come loose. Appears to be a bit of a theme lately. Top nut on the drop link on the front sway bar unwound itself and the link fell out of its hole. Hello oversteer.
Anyway cars goes crackle crackle pop pop on the over run.
To me your graph in the initial post looks VERY responsive for dash 5's, the boost plots in your latest post seem to confirm this.
Maybe the timing belt has skipped a tooth or 2?
Who tunes your car? Surely worth a call to Simon's tuner given the reliability and power he has gotten from all his ...um well utilised R32s :)
Well Ill ask him on the weekend but it is such a balls ache being messed about by Perth tunas that I am happy given the local bloke a go. He knows his stuff just doesnt get so many 26's. 10 hp aint going to get me near Simons things output plus he has all the gearboxes anyway.
If I can gear near 500 that will be a pretty good result. Working on the assumption the cam timing has shifted since it was tuned.
Edited by djr81
Haha, as of earlier this week I'm back up to 5 spare gearboxes... Was running low after breaking 2 in 2 days :)
With the boost controller fixed it now makes boost low in the range - so the number at 4000rpm is 270rwhp (With -5's so beat that with a stick) instead of 200. The tuna said it was fairly insensitive to ignition advance and had phased the cams as best he could.
Given the torque output is more useful further up the rev range what would people recommend for bigger cams? It has a 256 degree inlet and 252 degree exhaust.
Everyone has already said this but you don't seem to want to do it. Take it to a reputable tuner who knows nissans/rb26's. If you make that $1k a day then f**k me you can afford to take it down to Perth.
A lot of tuning shops offer a car service for $55 a day. Or just go down there early and make a day of it?
Wrong/poor tune can end badly. I drive a lowly old GTST and I won't let the 'local bloke' touch my car!
Dont even worry. What's the wortst thats going to happen...
Probably a bunch of unhelpful suggestions get posted.
Looked on the rb26 dyno thread there are two -5 poncam posts neither of which have printouts. Thinking my old chart may have been with a stuffed boost controller so cannot gauge the response from personal experience.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
