That would be a nope
so where you just messing with me before with 12k hp gtt? I've been Skyline man since my P's-so because I'm between skylines at the moment does that mean I should get off SAU? I'm trying to get help from you guys & decide wether to go manual or auto, is that a crime???
I'm importing r34 gtt to chase hp-will be w/e car & MAYBE try at drags once or twice, see what happens
get a manual. The auto is fine 90% of the time for a daily but there are times it can be a pain in the ass. and being a w/e you shouldn't buy an auto.
The lag from the converter, the sometimes non existent power, the flair on gear changes if it's not tuned and even after it's tuned if you want and make more power it will start to flair again until you do the welsh plug mod, then again when you make more power.
If you're thinking about doing some local twisties because you didn't mention the track, the awd auto is great depending on the road. Tight corners where you can stay in second is fine but anything over that speed you will only have the overdrive button to lock gears. Being rwd with power, if you want more power mid corner and it kicks down mid corner you may find yourself in trouble. The awd is much easier to control when this happens, otherwise you will have to find the happy medium with throttle position. I don't do many hill runs, but when i have i found the auto great being awd and easy to control and to get the most power all the time, i couldn't imagine it with a rwd.
thanks so much Trex, much appreciated. Gives me a bit to think about. Will not be doing twisties, just w/e & may try luck at q/m. I didn't think awd came in gtt(excuse my ignorance)-I thought only N/A gt4 or gtr(which in r34 out of my budget)?
i have a stagea. so awd auto.
ohh that was my next q, thought might be Stagea. The only issues I have with manual are that I live in Melbourne's North, lot of traffick, stop start(roundabouts etc) & tons of new speed cameras-I only have 1 or 2 points left. Not promoting hooning. Even our freeways suck b$&))! Because a lot have recently been dropped from 100 to 80- even 70 kms & new cameras been put up to reinforce this. But will still consider manul
thanks Cowboy1600, I am newbie here so appreciate it. I've also gone over some threads & saw that Hadouken just loves taking the piss(especially from newbies). It's ok, I think he just needs a hug haha
honestly, if you saw him a hug would be the last thing you'd want to do. :wub:
keep reading mate, it's the only way you'll learn and not get taken advantage. Most, if not all have been taken advantage of when changing platforms and learning new things. Keep reading and get a fair understanding on what is going on and how to achieve your goals before importing the car.
So you don't have a car, but will get 2 g tax return soon then shoot for max hp?
no, I have 2 cars atm(Commodore & VRX) & in process of buying r34 gtt(importing) & have 3k(seperate for r34 budget) & expecting another 3-4k with tax return. So 6-7k just for modding
haha will do chief, thanks.
Oh cool. Well that's the trans sorted.
Then you are left with a stock car with a sweet as trans.
so trans will cost 6-7k to build? Earlier in thread someone said 2-3k for trans but then Kinkstaa said he spent 10k. Can I not get built for 2-3k?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
