That would be a nope
so where you just messing with me before with 12k hp gtt? I've been Skyline man since my P's-so because I'm between skylines at the moment does that mean I should get off SAU? I'm trying to get help from you guys & decide wether to go manual or auto, is that a crime???
I'm importing r34 gtt to chase hp-will be w/e car & MAYBE try at drags once or twice, see what happens
get a manual. The auto is fine 90% of the time for a daily but there are times it can be a pain in the ass. and being a w/e you shouldn't buy an auto.
The lag from the converter, the sometimes non existent power, the flair on gear changes if it's not tuned and even after it's tuned if you want and make more power it will start to flair again until you do the welsh plug mod, then again when you make more power.
If you're thinking about doing some local twisties because you didn't mention the track, the awd auto is great depending on the road. Tight corners where you can stay in second is fine but anything over that speed you will only have the overdrive button to lock gears. Being rwd with power, if you want more power mid corner and it kicks down mid corner you may find yourself in trouble. The awd is much easier to control when this happens, otherwise you will have to find the happy medium with throttle position. I don't do many hill runs, but when i have i found the auto great being awd and easy to control and to get the most power all the time, i couldn't imagine it with a rwd.
thanks so much Trex, much appreciated. Gives me a bit to think about. Will not be doing twisties, just w/e & may try luck at q/m. I didn't think awd came in gtt(excuse my ignorance)-I thought only N/A gt4 or gtr(which in r34 out of my budget)?
i have a stagea. so awd auto.
ohh that was my next q, thought might be Stagea. The only issues I have with manual are that I live in Melbourne's North, lot of traffick, stop start(roundabouts etc) & tons of new speed cameras-I only have 1 or 2 points left. Not promoting hooning. Even our freeways suck b$&))! Because a lot have recently been dropped from 100 to 80- even 70 kms & new cameras been put up to reinforce this. But will still consider manul
thanks Cowboy1600, I am newbie here so appreciate it. I've also gone over some threads & saw that Hadouken just loves taking the piss(especially from newbies). It's ok, I think he just needs a hug haha
honestly, if you saw him a hug would be the last thing you'd want to do. :wub:
keep reading mate, it's the only way you'll learn and not get taken advantage. Most, if not all have been taken advantage of when changing platforms and learning new things. Keep reading and get a fair understanding on what is going on and how to achieve your goals before importing the car.
So you don't have a car, but will get 2 g tax return soon then shoot for max hp?
no, I have 2 cars atm(Commodore & VRX) & in process of buying r34 gtt(importing) & have 3k(seperate for r34 budget) & expecting another 3-4k with tax return. So 6-7k just for modding
haha will do chief, thanks.
Oh cool. Well that's the trans sorted.
Then you are left with a stock car with a sweet as trans.
so trans will cost 6-7k to build? Earlier in thread someone said 2-3k for trans but then Kinkstaa said he spent 10k. Can I not get built for 2-3k?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
