  • 2 months later...
Will be in my garage if i win Ozlotto tonight. What an awesome car.
I am going to have to start buyign two weekly tickets as I want this car is only a lotto win away from me buying it :) Every times its at RPM I ogle it...gorgeous and unique with history!
  • Like 1
https://www.sau.com.au/forums/topic/459144-2001-n1/#findComment-7639723
Thanks 'Roy' and 'West'. Over the time I've owned the car it has probably only covered around 5000 km. Each km has been savoured.
I hope you get lucky soon. The car needs to go to someone who will appreciate it.
https://www.sau.com.au/forums/topic/459144-2001-n1/#findComment-7639750
  • 6 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
