This was my old lag monster, didn't move until 5500 and 1st and 2nd had to bash the limiter to keep it on song
Useless piece of junk never again.
Rather a 2.8 and stock ceramic twins over my last set up
Edited by mr skidz
  • Like 1
XGTRX, I do not think you have to wait for your T04Z to thrash it, I think you do too much thrashing now :)
Have you got Parkinson's or some other medical problem where you cannot control you right foot to make a responsive car drive smoothly in traffic?
I have come to the opinion that you have to be joking, good one mate :cheers:
  • Like 1
Nah not joking. If everyone had the same opinions and likes and dislikes the world would be pretty boring. We obviously have different ideas on what the best Gtr setup is. But hey we are lucky because if we don't like what we have down the track, we just change the turbo and we have a different driving experience with the same awesome car.
We are pretty privileged I say.
The beauty of a responsive big power stroker is you can still pretend it's heaps laggy with the throttle, if that's your thing.
Can't pretend a lag monster is responsive...
haha, that is funny :special:
  • Like 1
You can stop now, your secret is OUT, you have a Stroker !
Boring so true. cars are like Sheilas, all different but all expensive :cool:
  • Like 1
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
