Hi all,
I have a r34 gtt with a gtx3076, link ecu, Walbro 450lph fuel pump ect.
Anyways its time to upgrade the injectors, I want to put something decent in which will allow me to run E85 down the track without needing to change injectors again. I will need to upgrade the pump & lines when the time comes.
I am looking at these deatschwerks 1000cc E85 compatible injectors:
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det/17u-06-1000-6-detail
Now the question is, are these going to be ok to run 98 pump fuel through without having a shocking idle & part throttle drive ability?
If its going to make the car real rough then I think I will need to go smaller now & then upgrade when I do want to go E85.
Sorry if this is a newb question, I have done some searching but cant find much.
Thanks in advance.
https://www.sau.com.au/forums/topic/459340-98-octane-through-1000cc-injectors/
They are a high flowed Bosch 550cc injector, so there are better options for 1000cc injectors available now.
http://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
Thanks for all the help.
Sub boy32 are you saying those deatschwerks are actually high flowed 550cc bosch injectors?
Wheezy what brand injectors did you fit?
What sort of power are you guys running on 98?
I wouldn't stress too much, most of the 1000's sold these days are 750cc injectors with the pintle cap removed. They spray perfectly well, and work better for e85 imo than the long nose 900cc injectors he linked, and cheaper.
Marketing hype...
Id1000
With the dollar the way it is, locally modified and warranted injectors are a much smarter option, considering they are exactly the same Bosch injector. Unless you like paying the ID tax...
The new 1300 and 1700s from ID are a whole new ball game though, internals are made inhouse with BOSCH motorpsort department... they are streets above the rest ATM.
The 1300's are only available through ID, but the 1700's are sold locally also. Not cheap though.
I was hoping to try them out in the evo but the 1400's I have currently will be fine with the Haltech elite i'm sure, and nearly half the price.
I wonder how much different they are from the stainless Deatscheworks...
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett/1200cc-fuel-injectors-6-detail
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett/1500cc-fuel-injectors-8-detail
Marketing hype...
We have done quite a bit of injector testing.
The spray pattern between a high flowed 550/750cc injector compared to the ones I have linked to are night and day different
The Bosch 1000's are designed for Ethanol, where as the 550s weren't......
High flowed injectors were fine when there wasn't the correct sized injector available.....but now Bosch makes 1000's, 1300's and 1650's straight out of the box now.
Edited by Sub Boy32
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
