I recently imported an R32 Skyline GTR to the US and I am having some trouble with the HICAS (I assume). Since Skylines are still new to the US (only '89s and '90s are technically legal so far) I figured you guys might be a better source of information than most of the people local to me.
The short version is: is it worth trying to troubleshoot a HICAS issue, or should I just get an eliminator kit? Does the HICAS provide any actual benefit? I understand what its purpose is, but I see mixed results about whether or not it is a good thing to have.
A description of the HICAS issue I am having is below.
If I accelerate hard to highway speeds (80+kph) while also turning (ex. using a circle on-ramp/interchange), the steering wheel will move off-center. Meaning the top of the steering wheel will be at the 11 o'clock position rather than 12 o'clock like normal. The car still seems to drive straight when that happens, just the steering wheel is no longer straight. After roughly 5 minutes or 10km, the HICAS light will turn on, and the steering wheel will automatically center itself again so the top of the wheel is at the 12 o'clock position and it will stay that way until I turn the car off.
Also, any time I drive at highway speeds for 5 minutes or 10km the HICAS light comes on, regardless of whether or not the steering wheel goes off-center like in the situation described above.
Any advice would be greatly appreciated. Sorry if this has been asked before. I tried to search but didn't see any posts with a problem similar to mine.
https://www.sau.com.au/forums/topic/459559-r32-gtr-hicas-issue/
In that case, do you guys recommend a simple lockout bar similar to this http://topspeedauto.com/nissan-skyline-gts-t-gtr-r32-89-94-jdm-hicas-bypass-kit-hicas-eliminator/, or a full kit like this one http://www.driftworks.com/driftworks-total-hicas-eliminator-kit-for-nissan.html?
Also, thanks for the feedback. I appreciate it.
Personally I'd suggest the hicas eliminator kit as you replace a tie rod and a (most probably) worn out ball join with a toe arm and new bushes
A lock bar is much cheaper, you might get some funny faces trying to get the rear aligned with all the hicas gear in there though
Edited by Jordy32
Driving a RHD car in a LHD country already gets me plenty of funny looks anyway. :cool:
I figured the full eliminator kit would probably be the suggested option, and I was leaning that way myself.
Unplug the small plug from the HICAS computer (in the boot, the box mounted on the right side).
Full eliminator kit is the way to go IMO.
Do you have an aftermarket steering wheel?
Do not have an aftermarket steering wheel, however I just imported the car from Japan 1 month ago so its history is mostly unknown to me and the exporter has not been good about providing information. I do have reason to believe it previously had a full roll cage installed so it stands to reason that other aftermarket modifications were installed at one time.
Edited by GoneGoose
The other things you (may) like to consider is all the pumping and pressure lines that serve the HICAS. You can just loop the thing and render it inoperable or you can do it properly and remove them. Also worth doing or atleast considering is replacing the standard power steering cooler with a small but decent cooler.
RE: steering wheels, sometimes the incorrect Boss kit throws the HICAS error (the computer can't figure out if you're turning or something).
But yeah, full eliminator kit is the way to go (it should include the loop for the power steering). Then rip out the HICAS stuff (weight saving!).
I echo this sentiment. Removing the hard lines all the way to the front is easy enough on a hoist. Looping at the rear is trivial if you buy a HICAS lockout or replacement kit that includes what you need. The PS cooler is just a loop of pipe and does very little. An auto trans cooler from an R34 is a bloody good size for the PS cooler.
Define issues? Do you mean just the physical problems of getting it out while the engine is in the bay? I wouldn't expect there to be. The solenoid can be removed with the engine in. The hydraulic lines to the pump and reservoir run under the engine and it is nice to be able to access everything more easily when the engine is out, but I'm sure that needn't be a problem if you're just removing the lines that run to the rear from the solenoid.
Mental note for anyone removing everything.....the R32 pump is a 2 stage (or more to the point a 2 circuit pump) with the rear circuit running the HICAS gear and the front running the PS. If you get rid of all the HICAS plumbing it is a prime opportunity to do something about getting rid of the 20+ year old PS pump in favour of a newer single stage pump. I did this by doing a Neo transplant, but that's cheating. I'm just pointing out that you can't just block off the HICAS lines as the pump is still pumping!
Thank you thats great! You can still use the standard power steering pump though right? If you were to replace it which would be the correct one?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
