All depends how far you want to go.
Oil and filter change, + what Johnny said.
Check over your cooling system, make sure it's well bled.
Bleed brakes with decent fluid.
Check pads for sufficient material, or replace with uprated items
Check tyres for sufficient tread, set pressures
Check all other fluids, PS, diff, gearbox.
Removed all random loose shit out of car
Pack yourself a little box with some tools and fluids.
The main things that stop cars on the track are overheating, and cooking brakes. And concrete walls. Avoid all three if you can.
  • Like 1
https://www.sau.com.au/forums/topic/459644-track-day/#findComment-7602655
Also if you can't afford an oil cooler at least get a massive radiator... GTS-t Skylines have a water/oil heat exchanger.
Those ling long dim sim eBay radiators aren't bad... I've got a Worley one for $170 and it's lasted like 10 track days.
https://www.sau.com.au/forums/topic/459644-track-day/#findComment-7602744
since you're taking out the radiator and dumping fluid everywhere just put in a new OEM thermostat.. if you're unable to get OEM get the Tridon highflow series.. don't get their normal one.. it doesn't flow enough.
https://www.sau.com.au/forums/topic/459644-track-day/#findComment-7603577
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
