So Team,
Pulled the trigger and updated from the very much loved 'Sonic' the 4 Door R33 GTST.......................
And purchased yet another 1996 Skyline (to much head shaking from my Wife!).
Picked it up here in Canberra, as it is really clean and had a good build list base to have plenty of fun in.
So what do you do when you buy a new Skyline the day after you buy it?
Take it straight to the track of course!
On the wettest day in Goulburn history.................................... Was fun in a new car though:
https://www.youtube.com/watch?t=20&v=Rrt48o6QsgY
Give me a wave if you see me!
  • Like 8
https://www.sau.com.au/forums/topic/459652-introducing-daisy-the-gtr/
^^ Yes, it has obviously been looked after, and TBH I really didn't have to buy it, but I see so many crap ones about that if the right one pops up, grab it. Wanted a 34GTR in BB but couldn't justify the extra $35K.
So, it pretty much has everything done,if you were rebuilding a car, but it has a few issues things that need changing.
Firstly it's running god damn rich... Took me about an hour to clay bar the rear bar after the track day.
So, I'll throw a Haltech, injectors and a decent pump in and an E85 flex tune, while i'm at it.
The -7 Turbos a bit small but are near new so will persevere with them.
  • Like 2
Thanks Shaun. She's a beaut. Can you please confirm it has stock AFM's? Looks like it but not 100% sure.
Also, can you remember the flow rate of the fuel pump? Looks like it may be pretty close to maxed as well.
Oh the other thing, are you able to adjust the rear shock dampers like the front? and if so how do you access the knobs?
Cheers,
James
You coming to the track day on 23rd? Be nice to see it then.
Probably!
why on earth did you buy my sway bars James, nice upgrade!!!
Yeah, itchy feet. The guy that bought the 4Door has a nice set of swaybars. Made a huge difference to the body roll.
  • Like 1
Oh Ok. How much? Miight be a baindaid solution though. Depends on what ESP come back with price wise for the Haltech.
are you going E85?
IDK how much, don't know if i still have them, but if i do i can let them go pretty cheap. I can have a look if you think you will need them though.
  • Like 1
sweet, well im back in the scene as well got rid of the projects and bought 33 Gtr as well a few months ago, any spots left in the track day?
Yeah its just a speed of the streets day.
are you going E85?
Cool, have a look and see if they are around ta.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
