well, say if he plans to put in a proper diff, a sequential box, a dirty 30, full brembos all round.... then no real diff if it's GTS-t OR GTS... actually he benefits... doesn't have that homo HICAS subframe
How much would I be looking at roughly to do an engine swap? + upgrading brakes etc?
Thanks to all those who actually replied maturely by the way! I've only just bought this car so I would love to build it up and get to learn things along the way.
& no I shouldn't have just bought a project car than because I just returned to Australia after living in Europe for a couple of years.
In the mean time instead of a turbo, is there really any other way to give the car a bit more power? The car has a K&N pod filter, heavy duty clutch, 3.5inch catback exhaust (which is way too loud) + a lot more I can't remember atm!
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
Other stuff, eg intercooler fuel pump extra bits involved that everyone forgets 500-1000
So 4-4.5k.
Selling your gts and buying a gtst will not cost you that much
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
So 4-4.5k.
Thanks for that man! Seems like selling and buying a gtst is the best way to go about it, cheers!
Or do you just enjoy being a dickhead throughout the day on the internet?
well in fairness, we ALL enjoy doing that, I know I certainly do.
Ben I can't believe you didn't say NOSSSSSS!!
but seriously you could mess about with little mods but by comparison to going turbo, not a lot that will give you dollar-value HP.
There is a lot cynicism in this forum on the topic of N/A power-ups, probably due to the number of young(ish) guys who have just bought an N/A Skyline and then come on this forum looking for a cheap power-up. They nearly always seem to think there is a magic solution that we all know but have chosen to keep secret. Sadly, there is no magic :-(
My axiom when it comes to modifying cars, learned through hard experience is:
Performance, reliable, inexpensive ... pick any one-and-a-half.
It is best to gather enough resources (ie knowledge, experience, parts/money) to do it once and do it right. Any other way will lead to much sadness.
Curb your natural enthusiasm, enjoy what you have got, and research the possible mods to make it better..
One day you too will have a mega Skyline like the rest of us, which makes your friends envious and which gets your girlfriend/boyfriend/farm-animal all hot and bothered (hey, I'm not judging), and life will be good. Dinks!
Edited by david.r34.gtt
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
