This thread is a train wreck. I approve.
Pics of RB20 coilpack setup.
Pics of compo received for the time (4 hours) it took to take maybe 10 bolts, some plugs and replace 6 spark plugs.
Edited by iruvyouskyrine
I bought a set of the same spark plugs just in 0.8 now it better fix it now i got a spare set of bcpr7es -11 if anyone want to buy $10 let me know only 100km used. Btw if this doesnt fix it im gonna link it hard
f**k YES i figured it out and it was the MOST STUPID REASON WHY!!! YOU WILL NEVER GUESS...
are you ready....?
ONE OF THE f**kING SPARK PLUGS WERE CRACKED INSIDE THE CHAMBER BECAUSE I MUST OF OVER TIGHTENED IT!!!
REALLY?? AND GUESS WHAT, as i was putting one of the new spark plugs in, I ALSO CRACKED ONE. So i put one of my old spark plugs from before i did the service back in. So tomorrow im gonna have to go buy one more spark plugs
f**k me im stupid, who would of thought tightening these spark plugs would make the white part crack??
seriously i wasted $50(coilpacks) + $60(coilpack loom) + $35(new set of spark plugs)+ the time spent travelling and the labour.
Learn this lesson from me, NEVER overtighten ANYTHING!
  • Like 1
You didnt crack it from overtighting it, you cracked it because you didnt hold the socket straight at some point while tightening.
If your holding the spark plug properly and tighten hard enough you will strip the threads in the head and the porcelain part will still be fine.
  • Like 2
this.
i was using the extension bar and it moves around the socket a bit. I got up to the third cylinder before i cracked it. I hope i didnt over tighten the first 2 cylinders...
a rubber insert in the long socket helps keep the spark plug central and will avoid cracking.
my god i have one with a rubber socket but i didnt use it, i think because the spark plug didnt go all the way in or it would get stuck in it.
When putting new plugs in, bottom the plug out in the hole by hand with a extension, then tighten 2/3 to 3/4 (max) of a turn extra.
So run them in till they reach the end, then tighten the last 2/3-3/4 turn more.
Just use your left hands fingers to keep the extension centered while the right hand turns the extension.
  • Like 1
man i feel so stupid because i even cracked one of the new ones and i think little bits of plastic fell inside the head....someone please call me stupid
because it would make me feel better :glare:
Stupid,stupid,stupid. You asked I delivered. Feel better now :)
  • Like 1
i'm pretty sure some awesome dude who knows heaps about european porn...I mean, cars...said
"spark plugs don't like being dropped. A cracked ceramic insulator can cause ignition issues"
spark plugs are one of the few things I use a torque wrench for, would suggest you do the same until you get the feel for them, or follow gtrpsi's guide above.
i'll also just say, I like your attitude, seriously. You were prepared to have a go at it...ok, f*ked it up, but, acknowledged your mistake and have learnt something in the process. As long as no major damage caused, not a bad result at all. Although, I you're seriously concerned bits of ceramic fell in the cylinder and you haven't run the car yet, pull out the plug and use a vacuum hard up against the hole, vacuum out any bits of insulator in there.
are you ready....?
Lesson is if it was fine before you touched it, then it's you.
It's always easier to blame everything else first though.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
