Sorry for delay guys, been busy. May be a quiet day at work tomorrow. I'll see if I can get those pistons under the big lit magnifying glass our sparky has on his work bench.
Head was dropped off yesterday, shop says I should have it back by the end of next week. Nissan stuffed me around with replacement piston circlips. Ordered 12 (was showing heaps of stock) but somehow they only had 10. Should get last 2 by next week. I hope anyway.
I mentioned to engine builder that I had 11 pistons and asked if I should aim to run the 6 that came out of the motor that's being rebuilt. Before I could finish my sentence he said he would pick out the best 6 from the pile. So that's what I've been doing.
Out of the 11,  2 where ruled out because of the maybe or maybe not cracks. 1 other was ruled out due to a tight 2nd ring groove (I may or may not have dropped this, lol). Out of the 8 useables, they where weighed and then the 6 closest weights where picked.
Nissan did a damn good job casting RB pistons. They're within 0.7 of a gram. Could have been 0.5 but I didn't like the look out of 1 of the other 8. There was 1 outlier that was over 1.2g heavier The 6 selected range from 404.08g to 404.78.
The piston pins are within 0.24g across the 6.
With some rearranging of the pin locations the total piston/pin weight comes down to  0.46g
Once the rod weights are factored in the variance comes down to 0.2g. if I shave a tiny bit of 2 pistons I can get it down to 0.07g.
I know this will make stuff all difference but I'm here and will take bugger all time to do.
Question time. Should I even bother with rearranging the pin locations or leave them in their original homes? If I don't the variance will be 0.43 with rod weights accounted for. Or do I go all out, shave a few pistons and end up less than 0.05g variance and call it balanced and BILLprinted.
Anyway here are my workings.
Thoughts gents.
  • Like 1
  • Haha 1
On 15/11/2023 at 12:15 PM, No Crust Racing said:
Given the are already so closely matched, do not touch them is my advise or you risk adding stress risers unnecessarily.
That's incredibly close.
Oops, my bad. Lol. I decided to leave the pins in original spots but went ahead and shaved around 0.15g from the 2 heaviest pistons. Going to take 0.10 off one more and call it done. BILLprinted baby.
This is the area I shaved material off from
KangaMotorsportsDatsun240zEngineBuildPistonAssemblyBalancingAreastoRemove.thumb.jpeg.fdffe2a075f36249e9dc0bc72b28e697.jpeg
On 15/11/2023 at 3:45 PM, Duncan said:
original locations, because then you don't need to worry about any sizing differences
As above decided to leave them in original locations.
  • Haha 1
As long as it's smooth and transitions from one plane to the next uniformally it'll be fine, I was removing 5g on some pistons and they've seen 800ks and 7k rpm already.
Doesn't mean they won't explode but who knows when ;)
  • Like 1
Just checked the ring gaps. Thanks Mr Nissan for being spot on and not needing adjustment. OEM is life.
Around mid spec for all. Starting to assemble the pistons now. Got 2 done so far, will continue at next opportunity.
  • Like 1
Geez man, where do you find 5 grams to remove. I only took .2 of a gram and was scared I was taking too much off.
Pic of my work
Shaved
Will clean it up and a bit with some fine paper tomorrow.
Unshaved
Rings are all installed now, will re weigh all pistons tomorrow with rings fitted up. I doubt there's much difference in the ring weights but you never know.
  • Like 2
On 15/11/2023 at 8:52 PM, r32-25t said:
The oil splashing on them will probably create a bigger weight discrepancy then you’re trying to shave off
Most probably true but what's done is done
On 15/11/2023 at 9:03 PM, No Crust Racing said:
You work all 4 sides of the pin boss taking them from square edge to tapered round edge all the way to near the crown.
Risky business lol
Yolo lol
Final numbers are in after ring fitment and arrangement. Variance is down to 0.12g worked out well, may be able to improve a tiny bit more with the arrangement of circlips once they all arrive.
Billprinting almost complete
I've ended up with 3 pistons from each motor. The 3 that came out of this one will go back to their original locations,  the others will be measured up and a spot selected for them.
Opened up the box of goodies from EFI solutions yesterday. Must say they're a well organised mob and everything they said was in stock actually was.
  • Like 3
EFI Solutions is a well oiled eComm powerhouse!
They probably have a proper ERP running, thus have real-time stock display on their eCommerce site. Not many car related businesses can do this, not even Sparesbox (Shitbox really).
  • Like 1
15 minutes ago, admS15 said:
You mean dropshipbox
Yep!
Waited a few months for my turbo, they then couldn't get the turbo, then offered a larger GTX3582R Gen 2, which I then agreed to, but what I received was what I initially ordered lol.
Wrote a bad review on Google, Facebook, etc. they then apologised and offered a free turbine housing 🤣
So yeah that's the story of how I got my Garrett turbo cheap.
Started on assembly on the weekend. I checked the mains clearance with plastigauge.  Was surprised to see bigger clearances with the ACL race bearings.  Was concerned the readings weren't right, so I disassembled and reassembled numerous times, measured with micrometre and bore gauge. The mic readings where close to the plastigauge but slightly tighter. I did the readings 3 times and although they where a tiny bit different each time, they where close enough for me to be confident what I'm seeing is correct.
Clearances on the mains are between 2 - 2.5 thou or .050-.063mm I was initially concerned as that's outside of Nissan's ideal range so I stopped assembling and considered running a -.010" bearing on 1 side in a mixed pair arrangement, sounds dodgy but apparently it's a done thing. You obviously need 2 sets of bearings. I have since been told that my numbers are fine, between 2-2.5 thou is good and I don't need to change anything. The avge across the 7 is around 2.3thou.
The rod bearing clearances where checked with the mic and they're a bit tighter at 1.45-1.77thou or .036-.045mm. Again I'm told that that's good and even a little looser would've been better. Will see what engine shop has to say about these clearances when I pick the head up.
Atm, the crank is in and torqued down, will start putting the rest together when I get time.
So the plastigauge turned out pretty close, if only I trusted it initially, could've saved hours of measuring, cleaning and unnecessary stress. Better to be sure than find out the hard way I suppose.
  • Like 3
  • Thanks 1
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
