if it really bothers you, just upgrade the rears too :)
OR... run a tiny bit wider rear tyres as theoretically the rears would lock easier
This is my concern, that the ABS will be fighting the rears and i will lose overall performance - i have the fronts on at the moment, just weighing up whether or not to buy rears before i head to the track next
You may want to consider a different master cylinder to match the piston areas so you don't end up with a long pedal.
Pedal feels ok at the moment, may be a different story if i look at larger rears as well
The ABS in the R32 is rubbish anyway - it is slow and generally pretty ineffective. Just be thankful its not all of that and leaking as well. I have found the Brembo setup with the Vspec master cylinder to be a little rear biased in any case so if you are happy with the pedal travel it is probably not far from being ok.
Did you fit a master cylinder stopper?
I've upgrade the fronts on my 32 GTS4 to GT-R fronts, without any noticeable effect on brake bias.
Given that the majority of the braking is done at the front, doing a bit more at the front shouldn't be a problem.
Its part of the reason why AP 6 pots are such a great upgrade for R32s with bigger rotors. Get more pad area, get more rotor so it all dissipates heat miles better than std but uses small pistons to reduce some of the braking torque you are gaining by going to a bigger rotor and better pads. So two steps forward and one step back means you still end up with nice front to rear balance on an R32 with std booster/masters.
If you go to a caliper with bigger pistons, and bigger rotor and higher u pad well you are doing 3 things that are all going to increase your front braking torque and in turn front bias meaning you are going to be locking brakes like a champion. ABS masks a lot...those of us without ABS tend to be a little more "canary in a tunnel" and sensitive to the differences between various setups
  • Like 1
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
