Then prepare your ears for tyre squeal and bulk understeer, or has it still got the oem suspension package?
I have $3,500 worth of custom valved Tein's (done by MCA) in there :D
(wanna buy my old Jap KTS damper adj gear i took out? lol).
Gonna put the RE003s through their paces if I can. Only issue is I do not have oil temp gauge, has oil cooler - so gonna have to stick to 2 fliers just to be safe.
Sounds like a fun day.
What if we wanted to come along but not actually go on the track, is there still a $225 fee? (read through but I couldn't find an answer).
Wanted to come along to the event and meet some people in the SAU VIC and get their thoughts on gtrs :)
If you don't have an oil cooler, you're gonna have a very bad time. Once you see oil temp hit 120 back off as it's gonna climb top 130-135 before it starts to come back down.
R888 will be fine, you'll run outta oil (and/or brakes depending on setup) before the tyres will give out
^^^ This.
Guys get your oil coolers sorted before Jan 30th, good chance it's gonna be hot. I had to do two cool down laps after pretty much every proper lap today to keep oil temps in check. Brakes were good (DBA T3 + Remsa pads + Dixcel 273C fluid) and the tyres (fresh R888R's) were great btw.
IMO track = oil cooler by default mate.
For $800 or so, it's cheap insurance and will let you run without any issues (and to the limit of tyres/brakes) all day long.
Any recommendations on what to get? Would prefer something RB25DET Neo plug and play with a sandwich plate (with oil temp/pressure sensor spots) and good quality fittings.
What are the details in terms of times? What time do drivers have to be there and when does the track close?
The venue open at 7 and closes at 6. Track action should start around 9.
I've run a justjap kit for years. No doubt a $1000 kit might perform better, but for $350 the justjap kit works well.
If you do get the justjap kit, Teflon tape all the fittings.
  • Like 2
Listen to this man 1st timers or this may happen
Sandown 11th Aug 2012 (5)
...don't ask how I know.
  • Like 1
How many cars will be on track for the timed session?
We're expecting 3-4 groups of timed cars. Groups are anywhere from 10-16 cars. It all depends on numbers on the day.
For the social event, when is the latest we need to sign up by? Is there a limit?
The Thursday before the track day is best. We'll end up doing entries on the day if we don't get the 80 cars max. But entries on the day slow sign-in, which slows the whole day a little.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
