Then prepare your ears for tyre squeal and bulk understeer, or has it still got the oem suspension package?
I have $3,500 worth of custom valved Tein's (done by MCA) in there :D
(wanna buy my old Jap KTS damper adj gear i took out? lol).
Gonna put the RE003s through their paces if I can. Only issue is I do not have oil temp gauge, has oil cooler - so gonna have to stick to 2 fliers just to be safe.
Sounds like a fun day.
What if we wanted to come along but not actually go on the track, is there still a $225 fee? (read through but I couldn't find an answer).
Wanted to come along to the event and meet some people in the SAU VIC and get their thoughts on gtrs :)
If you don't have an oil cooler, you're gonna have a very bad time. Once you see oil temp hit 120 back off as it's gonna climb top 130-135 before it starts to come back down.
R888 will be fine, you'll run outta oil (and/or brakes depending on setup) before the tyres will give out
^^^ This.
Guys get your oil coolers sorted before Jan 30th, good chance it's gonna be hot. I had to do two cool down laps after pretty much every proper lap today to keep oil temps in check. Brakes were good (DBA T3 + Remsa pads + Dixcel 273C fluid) and the tyres (fresh R888R's) were great btw.
IMO track = oil cooler by default mate.
For $800 or so, it's cheap insurance and will let you run without any issues (and to the limit of tyres/brakes) all day long.
Any recommendations on what to get? Would prefer something RB25DET Neo plug and play with a sandwich plate (with oil temp/pressure sensor spots) and good quality fittings.
What are the details in terms of times? What time do drivers have to be there and when does the track close?
The venue open at 7 and closes at 6. Track action should start around 9.
I've run a justjap kit for years. No doubt a $1000 kit might perform better, but for $350 the justjap kit works well.
If you do get the justjap kit, Teflon tape all the fittings.
  • Like 2
Listen to this man 1st timers or this may happen
Sandown 11th Aug 2012 (5)
...don't ask how I know.
  • Like 1
How many cars will be on track for the timed session?
We're expecting 3-4 groups of timed cars. Groups are anywhere from 10-16 cars. It all depends on numbers on the day.
For the social event, when is the latest we need to sign up by? Is there a limit?
The Thursday before the track day is best. We'll end up doing entries on the day if we don't get the 80 cars max. But entries on the day slow sign-in, which slows the whole day a little.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
