sorry fools didnt check compression today will do tomoz cause i know youre keen az to find out.
Peace
oh yeah i meant id sell the whole diff to recover $$. It is newish and houses 31 spline billet axles and a Full spool ok fool.
Don't bother with comp test. This is your problem right here and here I was thinking you're a troll. It all makes sense now, it was the FLUX CAPACITOR all along. Your mate who sold you the engine should probably help you fix it, don't ya think. Carry on with your pitiful pointless existence.
Gee dudettes dont get too upset.
I was after serious advise but being a forum = bitches starting shit, trying to offload their baggage from previous f**kups cause words on a computer are hard core these days and im so hurt and your such a boss im upset about the things you say.
i need anti depressants now..
thanks for antiadvise
But you see, now that there is not one single use of the letter z in your typing, I feel less aggressive and twitchy reading it. Not to mention that the quality of your prose has changed from being borderline gibberish to very nearly completely normal. I'm sure that the negative responses to your initial post were not purely because of the initial post itself (which was not actually as bad as I just made it out to be), but more because of the fact that there were elements of the story (later dropped into your posts in an aggressive way because we weren't able to read your mind) that probably should have been presented up front in order to avoid people leaping to the usual conclusions. The usual conclusions are usual for a reason. When dropkicks buy half munted skylines these are usually the first posts we hear from them.
This is not to say that the negative responses to your question were completely justified, but to point out that there are ways to approach these issues when posting on forums that help to avoid being painted as an arsehat from the outset.
Check your replies to my post Fool, have you forgotten your the troll king. I am simply responding.
In other news, I put some new plugs in today and fired her up with the low km OP6 turbo and she loves it, no smoke, no misfire.
I will take it for a decent run tomoz and see it goes. didnt comp test yet i need a hand.
Yeah thats my old username from 08 when i had a r31 what of it fool ? New car New decade New name
in other news:
i wrote a list of shit to check easiest to hardest and got it on the second check but i dont completely understand why just yet.
intake filter remove - so no vacuum if too blocked
check breathers - open up, re attach oil catch can
check oil drain when running - so not blocked
try 1mm restrictor again - even though journal bearing turbo, oil feed psi may be to high
check intercooler for blockage - oil from f**ked turbos or insects from sitting 2 years
I removed pod filter.
I previously had taken off the oil catch can for rego & simply put a loose ish hose from one breather to the other, after i took this off and left it open i noticed no oil coming from front or rear turbo housing.
Now i have other probs lol but easy fixes.
yep its the third one i fitted that why i knew something else was up. i assumed the 1st 2 were f**ked as the people i got em off didnt use them. I get bad luck but surely not that bad.
so now i should put the bigger turbo back (3582)on or maybe just the bigger front housing if it fits the current OP6 chra and up it to 20psi & see what she does.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
