5 in a row is as many as Hamilton has ever managed!
And only 7 other drivers in history have won 5 or more in a row!
http://www.motorsportmagazine.com/f1/history/consecutive-wins-in-f1/
Now 7 in a row, equalling Schumacher and Ascari's record and only one other driver has ever in F1 history won more consecutive races - Vettel...
It has also put Mercedes 2nd in team consecutive wins, equaling Ferrari's 10, with Rosberg contributing more to that tally than Schuey did over Rubens. http://www.f1fanatic.co.uk/2016/05/02/mercedes-poised-to-equal-wins-record/
Team Wins First Last Drivers
McLaren 11 1988 Brazilian Grand Prix 1988 Belgian Grand Prix Ayrton Senna (7), Alain Prost (4)
Ferrari 10 2002 Canadian Grand Prix 2002 Japanese Grand Prix Michael Schumacher (6), Rubens Barrichello (4)
Mercedes 10 2015 Japanese Grand Prix 2016 Russian Grand Prix Nico Rosberg (7), Lewis Hamilton (3)
Red Bull 9 2013 Belgian Grand Prix 2013 Brazilian Grand Prix Sebastian Vettel (9)
One more to equal McLaren's 28yo record....
Edited by hrd-hr30
Maybe the stars will align and Homo will get a car that works at a GP he gives a fk about. Maybe. Or Sebastian McSwearface will not back off half way through a corner and get shunted again.
These sorts of records are all bullshit anyway. Jim Clark won his championship (One of two) in 1965 with 6 wins out of a 10 race season. Except he didn't turn up to Monaco so it was 9 races. Worth 54 points in total for the WDC. About what you get for winning in China & Mongolia or similar.
Cars are massively more reliable than they ever were and advantages gained are so entrenched by the rules and politics as to be laughable. Used to be just Ferrari would veto bad decisions because it gained them a temporary advantage. Now everyone does it.
modern era is all pretty much the same- certainly for Schumacher, Vettel, Hamilton etc. If anything cars have been less reliable in the past few years than any other time in the last 30yrs! Similar season lengths, but that doesn't really matter anyway - consecutive wins carry over. And points don't come into it.
Edited by hrd-hr30
They just stuffed up strat wise. Shit happens unfortunately.
Yeah pretty much how i saw it. Split the strategies, they even said at the start that the 3 stop was supposedly quicker so on paper it probably was a good idea
yeah everyone had said the 3 stopper was better and they gave the lead driver what they though was the best strat and the other the alt and just turns out the latter was better...
is that why they dont allow alternate strategies at merc?
Problem being his pace on his second last tyre set was rubbish. They looked to be going away at the end worse than Verstappens. Problem with that observation was there was a point midway through the race where Vestappens pace fell away and I thought his tyres are shot. But they hung in there so who knows.
Anyway RB looked to have two good drivers neither of whom appear to be knobs. First time ever?
  • Like 1
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
