Nismo Cluster in good condition and working order.
has the usual crack in the speedo cable connector, but does not effect operation.
done 67779km.
$580
Nismo Horn button in good condition
$150
Nismo Cigarette light, its brand New never used.
$230
BNR32 Vspec genuine BBS wheels with tyres. 17 x 8 +30
Wheels have been professional repaired and repainted to the original specs
they're in perfect condition.
Tyres are yokohama 225/50/17 DB decibel with 4mm and 5mm treads.
$1300
Located at mortdale and happy to ship at buyers expense.
0449 292 986
thank you.
  • 8 months later...
Hi Roy,
I'm wondering if the Nismo Horn Button is still F/S?
I'd like to know if it fits my wheel too before buying?
Regards, Terry
  • 1 month later...
11 minutes ago, elinaki31 said:
They are on my car. Keep a lookout on ebay they do pop up.
Haha no worries, thanks for letting me know buddy :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
