Hello, i've recently done a turbo brake conversion on an n/a, all seals replaced and caliper bores and pistons cleaned before installation. but when i took the first drive there was a sound in the rear like fluid being forced out, upon stopping there was fluid on the outer lip of the disc and fluid all around the wheels, not enough to be dangerous but eventually. so i put it down to a faulty caliper as it had a speck or two of surface rust and replaced them with better condition ones, these have the exact same problem and im so confused, im assuming its the piston leaking but im hoping its the new HEL braided lines i installed as the 34 gtt lines have a little bit of thread exposed from the caliper
Any help would be really appreciated because i need to drive it and done wanna pay drug money for a shop to look at it
https://www.sau.com.au/forums/topic/462690-brake-fluid-leak-help/
Take your wheels off where it's leaking and clean the discs, calipers and lines with brake cleaner. Once it's all completely dry, start the engine and pump then hold the brake pedal a few times. Then go back to the brakes and have a look where the leak is coming from. You may be able to see if it's coming from the line itself, the connection of the line to the caliper or the piston.
The problem is it never leaks when the car is stationery, when it picks up speed and I brake there's the hissing noise and it spits fluid, but only when it's moving
There's a little fluid around where the line goes in but there's fluid on the edge of the disc aswell and I can't see how the lines could leak onto the disc
It doesnt make sense that it only does it when you're driving. Follow Dark26's excellent advice, just make sure you press the pedal as hard as you would when driving. Also don't discount that it could even be the new lines.
  • Like 1
I sat there and pumped it for a while and I can feel a tiny amount under the lines, so I'm replacing the lines, I agree it doesn't make sense but whenever I try it never gets at wet as I expect so I just dismissed it.
Still I'm baffled that fluid from the lines can make there way onto the rotor
If you pump it up a couple times how is it any different to braking while driving? The only difference is the pads are doing their job
It's not exactly different but you may be braking differently in your driveway than when you're driving. You haven't said how long you were holding the brakes in the driveway so I'm assuming that while driving you're holding the brakes longer for stops. If I went for a short drive for testing, I would probably slow down to almost stopped from 60 about 5 or so times by the time I make it back around from all the T intersections/corners I have to turn at. It may not seem like much but you may not be braking the same amount in your driveway as you do while driving, that's where I think the difference is. Try pumping the pedal a few times and then hold it down with firm pressure for about 10-15 seconds, if you don't notice anything repeat this a few times.
Well my current thinking is the lines, I did find paint flaking from the area and looked into whether the 34 lines are right for the conversion and it seems the 34 calipers have a much deeper fitting for the lines, I'm thinking this isn't making a good seal since half the thread is exposed
33 lines are ordered so we'll see if that's it because two sets of good Nick calipers failing can't be a coincidence
Are your new lines the same type of connection as the calipers? When I fitted some GTT brakes some years ago I had to convert from banjo to screw in type (or the other way round - can't remember now) and had to remove the olive from inside the caliper.
I think Bob's on the right track.
There are 2 fitting type, one has a flare on the end of the brake line with an angled end that seals on a similar angled end in the caliper (the "olive" Bob mentions). The other type uses a banjo bolt that seals with a copper washer between the head of the bolt and a (hopefully) flat part on the caliper where the bolt screws in.
If your brake line has the copper washer/banjo setup it needs to seal tightly to the caliper, and it won't be able to do that if the banjo bolt bottoms out on the original fitting before it is tight.
So to check that you can look at the copper washer; they are designed to crush a little when they are tight.
The stock ones didn't use a banjo bolt, just an unnecessary bracket thing, but they screwed in fully whereas the new lines have this hardline tube coming from the threaded part which stops it screwing in more than halfway
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
