Hello all.
Can anyone who races their 32 point me in the direction of a rear wing or lip that actually works. I have a GTR wing on my car and at speeds approaching 200 the back gets very very light. I have a front splitter to keep the front under control but am curious to what other people run cheers.
https://www.sau.com.au/forums/topic/462837-r32-aero-problems/
Depends on $$ and how much 'race' you want vs look etc
there are alot of fast cars around without any aero etc so obviously make sure suspension, tyres etc sorted first
Obviously the proven bigger 'GT' rear wings are there being Voltex, Topstage and APR - with the AUD going down so much it puts even the basic versions of the above into the $2.5K mark though
A rear lip probably wouldnt do much at all compared to a proper wing
on r32 gtst had a basic Origin 1700mm CF rear wing on and put a gurney flap on it... made the car feel solid in the rear.. though have absolutely nothing to compare it too so probably doesnt mean much but a decent starting point .... the angle i ran it etc prob causing too much drag vs downforce etc
recently it snapped going 200ks + so now going Topstage rear wing
when the wing snapped at tunuing session came in took it off went out 5 mins later so same track / tyre temps everything car felt very noticably unstable in the rear after that
its also about balance front to rear, i dont run a front splitter yet so I understeer alot, so yes your front splitter on vs no decent rear wing would prob make rear more unstable to usual ?
Edited by bcozican
  • Like 1
The front splitter is a new edition. At the high 100's before the front felt like it was off the ground and the rear would threaten to come around if the wind shifted down the straight. I don't really want to rip the GTR wing off and would prob go a full wing on a spare boot lid. I don't want to pay thousands either.
Anyone use a lip/rear diffuser combo?
Also I run bilsiten all around with adjustable whileline sway bars front and rear. Front and rear strut bracing and a half cage. Also full nolethane bushes and camber cancelers. I couldn't say the set up is horrible. It has a little understeer and a pretty passive rear with predictable oversteer through bends. It is however a very stiff set up.
Edited by Weaselman
Interesting. I have no such issues with that wing on my GTR on the track. Nor have I heard of anyone else having issues like you describe with standard wing. Possibly a problem elsewhere that a big GT wing will only mask?
Btw also I notice your car is super low. From my conversations with the ppl that built my GTR this is not ideal due to roll centers etc. Also I've noticed that they've setup my car with the front visibly higher than the rear. I can only assume this is due to needing front suspension travel and having a front heavy car with a cast iron block. "About a 100mm off the ground at lowest point is about right"
Either way the handling is night and day compared to when I first got it from Japan when it was super low with rock hard spring rates. Now running Racepace coilovers with white line sway bars and some minor bushes changed here and there.
Looking forward to seeing what the final solution is for you
  • Like 1
I understand that the R32 GT-R rear wing produces something like 120kg downforce. It may just seem like its light in the rear because the front splitter is generating better front grip.
Just looked at my Nissan Race Team GT-R models, and they just have the Gurney lip thingo across the rear of the bootlid, so it would seem that might be the way to go.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
