Hey guys, i just brought my first car today, its a 1987 TI and it has a blown motor. I found a motor out of a vl and i was wondering if it will just slip straight in and run with the skyline ecu or will i be better changing the ecu's? and will there be any other problems ill run into? thanks:)
Edited by mr30Turbo
https://www.sau.com.au/forums/topic/462980-rb30-holdern-into-a-skyline/
The above ^^ is only relevant to twin cam rb30 builds.
Yes, the VL rb30 will work in an R31.
You will have to change the harmonic balancer depending on if you want to run R31 or VL accessories.
Easier to use your crank angle sensor and distributor your ECU was already using, you cannot interchange CASs (vl - hitachi, r31 - mitsubishi) only the distributor as a whole. Use the same alternator.
  • Like 1
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
