Hey guys,
I just bought my R34 two days ago, it runs good and I love it. I noticed the previous owner had a APEXi ECV exhaust control valve fitted to the exhaust and control lever next to the hand break. I asked him about it and he said he hasn't connected it up. But the next day I looked under neath the car and saw it is connected but the butterfly valve isn't moving. That's not why I'm here though. I saw that the valve is located in the centre of the car's exhaust pipe. Normally they would be fitted at the end of the bore right? Have a look at the pics:
From the other side (passenger side)
My concern is if that butterfly valve were to close, the exhaust fumes have no were to go. Usually they fit these control valves onto the end of the aftermarket exhaust and have an extra hole behind the valve so when it closes the fumes are forced into that opening and will travel down the length of the muffler usually 3 times before it exits (so I've heard) and that makes the muffler silent. Does anyone about these things? Does that setup look right? I'm planning on making the valve work so it will be handy to use for when I'm starting my car at 5am in the morning so I don't wake everyone up in the neighborhood, or if a bored cop tries to follow me.
Edited by Joni Boi
The valve is never fully shut, also doesn't matter where it sits.
Less exhaust flow means less noise.
Oohh really? I thought it would shut it completely
Yeah, I'm thinking of taking it apart and see whats what. Just seems odd why it would be located there, that's why I'm asking if anyone has seen this before.
What you're describing/expecting here is something like the varex muffler (as below), what you've got is just a butterfly valve in the pipe, which should have a mechanical way of stopping it from being completely shut. The only reason I can think of placement would have an impact is if the valve couldn't handle the heat being closer to the turbo than say the muffler which it's had a split second to cool??
I bet you'll find the valve plate is either limited such that it can't fully close as John suggested
OR the plate has a heap of small holes to restrict the gas flow/noise.
A bit like the sheet of holey metal we'd slip in the cat flange joint to instantly lose those dB.
That's exactly what I had in mind. I've never dealt with these things before, that's why it was odd to me.
Yeah must that. Thanks guys :biggrin:
Edited by Joni Boi
    • Well, i've been told it's going to be in Poland around october - november. It should set off by the end of this month. Waiting for it to arrive is the easy part, searching for the right car, wake up in the middle of the night to see the photos and decide whether to bid or not - that was difficult
    • Thanks mate, i'll keep that in mind. Not sure though if the black carpet will fit grey interior. I'd prefer original Stagea set but if i fail to find one in another few weeks, i will probably come back to you. p.s. - is this original, licensed Nismo product?
    • I'm a strong believer that old sports cars should be reserved as weekend cars and owned by mechanically inclined people. The risk-reward ratio is only acceptable under those conditions.
    • @Stringycheese hopefully this is helpful. 🤣
    • Welcome Marek! When does it arrive? Waiting sucks.
