Gday
We have put together two teams to run in the NSW RRC - 6 hour endurance relay event over 27/28 March
We will run 6 people/cars per team and you are on the track for as long as you want, You then pit and swap to another car in your team who continues on. There is a point scoring system to allow everyone equal chance of winning. It is a 2 day event, practice and qualifying for the event will be on Sunday 27th March, race Monday. Regs are very very relaxed no more than what you would need to go to a speed off the streets day.
We still need 3 drivers/cars so please let me know if you are interested and you can join in a very fun event! Racing at SMP north circuit.
All regs are below for you to check out.
Approved2016 Regularity Sup Regs FINAL (1).pdf
Entry form part A - B 2016 Regularity Relay_v2.docx
Pitlane Map.2.pdf
Scoring NSW Road Racing Club 6 Hour Regularity (1) (1).pdf
https://www.sau.com.au/forums/topic/463206-nswrrc-6-hour-relay-team-28-march/
Very interested in this but I need to work out the overheating issues in my car before I even consider it.
When do you need to know by? And how much are we looking at for the entry fee?
  • Like 1
That f**king sucks.....post up some pics somewhere because you never know who will see it at a track one day....it can be a small world sometimes.
My trailer went walking too but was recovered the next day due to CCTV
Sounds cool, but my now dedicated track car cant move, bastards stole my trailer...
on the bright side, at least the car wasn't on the trailer.
Hope it comes back soon.
As Duncan said, can be a small world, hopefully it's found at a track.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
