Hey gents, have done a little digging into trying to find out about actuators after a member here suggested I fit an R32 Actuator or HKS Adj Actuator to increase my boost slightly (min 10psi to 12psi max).
Was wondering how I could go about making the purchase I.e where I can grab one, how difficult it is to fit etc for the both (have read the HKS might not be so flash at 10psi)
Running stock boost, only modifications I've made so far are an Apexi Power Intake and Splitfire Coils. Starting out small but enjoying myself! Still planning to upgrade to a catback as part of my stage 1 noob mods.
https://www.sau.com.au/forums/topic/463360-noob-advice-for-actuator-r34-gtt/
if you're going to spend HKS money, you could also consider a turbosmart adjustable unit, which are much better quality units with better tension points and come with a set of different sized springs to set the psi, rather than a screw/spring tightener system that the hks and garrett units have
the point of upgrading the actuators on a stock turbo is only if you are running increased boost pressure, it is beneficial to have an adjustable wastegate actuator to be able to deal with the increased exhaust back pressure. this allows you to hold peak boost for a longer period, where the stock actuators which can't maintain the increased boost pressure will taper off at peak boost
upon googling, i found this good tuning guide for a stage 1 upgrade
http://nissanskyline.6te.net/tuning_GTT.htm
all the best
I wouldn't do that on the stock ECU, R34 GT-t have a pretty premature TP Load cut.[/quote
Rule this out then? I'm not even going to entertain the thought of the next stage of mods I.e ecu, injectors, tunes etc.
Just wanted to see if there was a viable way to increase by boost by 2psi
Run 10psi on a cold evening in a R34 GTt and it will hit the TP Load cut.
Rather spending your efforts on a good turbo back, a good intercooler then focus on more boost when you can afford a Nistune or better.
^^^ What Johnny said. There is no 'quick fix' way to magic up power reliably, start with some planning so you can do it once, do it right.
Well there is. If you follow my suggestion you will get the extra couple of psi OP is looking for without spending a cent.
Fair enough. Will it run ok and with safe AFR with no tune?
I cant see why it wouldn't. its just a simple bleed off which is exactly what a manual boost T controller does.
surprised I haven't seen this method posted before.
I did it to my car when it had an RB25DET and it gave it a little more zip with no adverse affects. A mate at work did it to his Stagea and gained a little. Not the same as a massive turbo but it doesn't cost anything.
Are you forgetting that the stock boost of the R34 is 7 PSI. This is just bypassing the 2 stage boost solenoid to run the full 7 PSI from 3000 RPM. He will have the same boost even after doing this mod......unless he drills out the restrictor hole.
Edited by duffmansbrew
only issue with SK's method or a MBC is he will need an aftermarket boost gauge to see how high the boost is.
drop in a known working R32 actuator and eliminate all stock controls and you have a reliable 10-11 psi.
whats the point of raising boost a few psi on stock turbo, last time i drove with stock turbo i wanted to burn the car, big 10kw's is a waste of time, just follow the normal route which is exhaust, boost controller, intercooler, turbo, computer blah blah
raising boost on a stock exhaust is gay. .. sorry
Edited by AngryRB
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
