^ Wouldn't mind knowing this also, and was it the same method for the pods at the rear?
FMIC looks great! Did you find you had a lot of FMIC hanging below the bar touching on the splash/under tray or was the fit ok? Also, did you require much of the bar to be 'shaved' to accommodate for the cooler?
  • Like 1
Hey guys! :)
To attach the side skirts and pods i used a few little dabs of sikaflex and/or double sided tape depending on the size of the surface as well as some the supplied screws which JSAI sent me along with the skirts and pods.
In regard to the front mount i didn't really have much of a problem with mounting it as it previously had a turn flow inter cooler installed. I can imagine that you would need to shave maybe 50mm off the front bar to fit it, however the blitz turn flow seems to hug tight to the rad support area as the pipe goes underneath.
As for ground clearance i don't feel this is much of an issue (YET) as i am not overly low, i have retained the stock splash guards and under tray, however they did require some trimming, i took a 7cmx7cm chunk out of the drivers side area to fit it back on correctly but you can't see this until you're under the car.. :P
  • Like 1
Seems to always rain only shortly after a wash!
Skylines are like a crack/meth addiction... the only detox is a free C63 AMG which will never happen LOL
Sorry to take this off topic, but been reading your website. Excellent read, especially for a guy who's learning like myself!
  • Like 1
  • 4 weeks later...
A while back i posted a big upgarage box, well i feel it's time to show you what's inside!
Genuine R34 GTR wing with NISMO Carbon Fibre spoiler blade! I got the wing and the blade for less than the blade brand new which i was very happy about.
Carbon Goodness
Sent it off to get painted by a mate's shop, this took a while as it was a cashie but that was no problem.
Very happy with how it turned out
Keen to get out for a drive on the weekend and get some proper photos!
What's next on the car you may ask!
Brake pads, disks, and lines with fresh fluid is up next, currently the brakes are flogged out and need replacing so I'm just going to do the whole lot at once and while I'm there ill slap in a HICAS lock bar, surely that doesn't need explaining :P
  • Like 3
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
