My picks to suit various budgets - it is more important to change every 5000kms / 6mths whichever comes first, more so than a more expensive oil over a longer interval.
Under $30 - Gulf Western Syn-X 3000 10w 40 - solid performing semi-synthetic (refined mineral base) only published figure is the TBN of 9.02 (solid for 10,000km intervals) and good pour and flash points.
Over $40 - from light to heavy 40w oils - Shell Helix Ultra 5w40, Nulon Fast Flow 10W40 and Penrite HPR10 (10w50 extra 10 which is just a strengthened 40 weight) - all use a Group 3 refined mineral base, however they improve on the Gulf Western oil by meeting the synthetic standard of ACEA A3/B3, as well as many euro extended-interval standards such as Mercedes 229, and BMW ll-04.
Over $80 - my pick would be Redline's 10w 40 standard motor oil, which offers IMO the best combo of detergent for street, and high temp/sheer resistance for performance (HTHS of 4.4, compared to the Shell which has a rating of 3.68).
All these oils have a good combo of cleaning detergents / high-temp/sheer performance - IMO the difference in competency isn't alot over a 5,000km/6mth interval of street/spirited driving.
Factor in track time and extended change intervals, and the more you want to consider a higher priced oil like the Nulon, Penrite and Redline.
Edited by squareznboxez
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699233
Penrite 10 tenths racing, Motul 300v or Mobil ultimate allround performance.
Those 3 oils are one of the best out there for turbo charged cars. Viscosity is obviously dependant upon engine mods, driving conditions and weather.
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699334
Agreed these are out and out performance oils, however they are designed to be run on track at high temps with high sheer stability (which is good), and then changed after each event - the result is the detergent package in these hi-performance 'track oriented' oils is usually poor and not ideal for day-in-day-out start/stop accustomed to a street car
the 300V is now specifically a track-oriented oil, with very little detergency for 5,000km/6mth intervals
the Penrite 10 tenths isn't far behind however they should have some street manners - my pick is still the HPR10, but the 10 tenths does have a Group IV PAO basestock, where the HPR10 uses a Group 3 refined mineral base
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699508
I did a little research based on what you said and 100% agree. Motul 300v is track oriented.
To the OP, i stand by the Mobil ultimate all round performance as its one of the best oils out there made for high performance cars. Its more expensive (around 100 dollars for 5litres) but its pretty damn good. To put it in perspective, i have been told a few guys have used this oil in their old ferrari's and its never skipped a beat.
HPR is also pretty decent. My mate is running penrite Everyday fully synthetic in his G6E turbo which is pushing 330rwkw.
You shouldnt really go wrong. Ive tried different oils in my evo ranging from castrol edge, motul 300v, penrite hpr, penrite racing, mobil ultimate all round etc.. and by far mobil was the best for daily driving.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699770
You're on the money with Mobil 1, based on many UOAs (used oil analysis) in the US, this has proven to be a very, very competent street/track oil
Although they have changed to a refined mineral base but extremely competent additive pack making the overall product possibly better than the previous Group 4 basestock version
The RRP of $105 is a lot of money though, and i think there are better street oils out there like Redline, Amsoil and select Elf.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699802
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
