I got a 6boost manifold, can't fault the quality of it but there extremely poor customer service would be enough to stop me going back to them
Whats the story there, i met the guy in person and he seemed a decent bloke.. met me on his way to brissy to save me postage too.
Waited like 12 weeks for the manifold with no updates and my messaged getting ignored, when it finally arrived it didn't have the wastegate with it, countless more messages, unreturned phonecalls and 8 weeks later still no wastegate, he tries to blame it on turbosmart, I rang them directly and had it 3 days later.. 6boost say they will make it up to me and send a few t shirts and turbo beanie, of course they never arrive either, messaged him about them a few times and no reply
That's no good, i thought 3 weeks for the Sinco was a while but that's a rediculous amount of waiting.. They should have a pile on the shelf or something considering how popular RB's are...
Nothing has changed it seams.
  • Like 1
Thats odd. I emailed 6boost yesterday and got a reply this morning
Im not excusing them for the above story, but you have to remember that its a business that started with one person and has grown slowly to what it is now.
Again, im not defending them, but i think its great to see what Kyle has come from to what it is today.
Ordered my 6 boost on August 27th. He didn't make me pay until the date it was done and ready for shipping on September 15th. He shipped the next day. The shipper delivered the manifold to the wrong person (in another state in the USA) on September 29th. Due to shipper error and the fact that the tracking information no longer worked since they checked it off as "delivered", Kyle started making a new one. The DAY before the new one was going to be shipped, the original one showed up at my house on October 22nd. Notice that there was likely only 1 month from date of order to date of arrival with exception of the shipper error (and actually it wasn't the international shipper, it was labelled incorrectly when it arrived in the states by the USA shipper). I had approximately 40 emails in exchange throughout the entire process including questions prior to order, updates, and the shipping issues. HYPERTUNE is the one that turned me on to 6boost originally. Since I'm in the USA I figured this was exceptional communication and delivery. The product is INCREDIBLE for the money for sure! Not all of the emails were responded to immediately, but 95% of the 40 or so emails were responded to within 24 hours.
My experience at the end of last year. Patrick
Where abouts are you in the USA? I'm going there in November. Might need to come check the 32R out ;) (Assuming it's a 32 as you guys can't get the others yet) :(
I'm in Lafayette, LA. My brother lives in new orleans which is only 2 hours away (great french/Spanish creole culture). Let me know I'm sure I can meet up / give suggestions.
We are going to LA! Awesome, would b good
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
