Hi all, I am from UK and recently purchased a R32 GTR N1 from Japan and due to be with me in 2 days time. I am very excited as I sold my last 32 GTR 10 years ago and now I am back with a GTR that I love. I will keep updating this thread as I am planning to drive the car and not just a garage ornament! I have bought lot of new OEM parts to refresh the car such as new carpets etc. Herewith few photos in Japan :)
Edited by AHSAM421
  • Like 7
https://www.sau.com.au/forums/topic/464125-sams-r32-gtr-n1/
As much as i hate to be thr one to burst your bubble i dont think you will find its an n1. Wrong side skirts and boot lip spoiler is missing. Also has mesh in front bar and no brembos
The chassis number end with a ZN, and this is a non V spec N1 hence no Brembo. Side skirt and boot lip are only option on N1 and those are Nismo version part. Also there are no mesh. Just get the fact right :)
Edited by AHSAM421
https://www.sau.com.au/forums/topic/464125-sams-r32-gtr-n1/#findComment-7709758
As this car is focused on originality, therefore any parts I put on will be easily removable smile.gif
Today I changed the pedal pads as they are a bit old but not worn out. But they are very cheap so I thought why not
Edited by AHSAM421
https://www.sau.com.au/forums/topic/464125-sams-r32-gtr-n1/#findComment-7717643
Next is the bumper lower lip spoiler. As the car came with color coded lip and I like the original grey color oem look so I took the old one off and replaced with a new one which i bought last year ....i know i know.......rolleyes.gifrolleyes.gifrolleyes.gif
It was a fairly straight forward swap apart from some very stubborn fasteners on the old lip. However, I am surprised by the condition as all fixing point are still intact and all in good shape. May keep it for spare instead!!
Then the sun is finally out after i finished!!! Well happy with the OEM look color combo smile.gif
Edited by AHSAM421
https://www.sau.com.au/forums/topic/464125-sams-r32-gtr-n1/#findComment-7717644
Sorry i dont think is good idea to disclose frame number in pubic, if you are so keen to know you can ask Terry with the V spec 2 N1 and he know my car is real deal :)
If you don't know you can check the VIN on GTR-Registry.com and find out it's build # too :)
https://www.sau.com.au/forums/topic/464125-sams-r32-gtr-n1/#findComment-7717834
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
