The way the E85 gets chewed up on spirited drives, a drum , 200 odd Lt ( 3.5 tanks ish) would not last much longer than 2 to 6 months if you drive it 3 times a month. Depends on what you call going for a drive is. Either way I doubt you would have a condensation problem.
Just have to wonder when you buy it from the station how old it is before you buy it ?
I was worried about the E85 I bought before I had to put my car in for some work and had it for over 8 months in 20Lt containers , tipped it in and off it went, just have to love those flex fuel sensors :)
"If" I used E85 all of the time 200lt would not last much more than a month or 2 at the most. But it is good to use 98 pump , then run it close to empty and when the 85 goes in you can get the full benefit of the difference :)
If I did not DRIVE the car, I would not even buy E85, it is a pain getting it where I live but it is so much better than 98, see Paul, you win :)
My car is a weekend only 2-3 times driven a month.
I bought some ethanol treatment for condensation so I'm more worried about the safety of transporting a drum full on its side in the back of the Territory.
I also bought and e85 tester so I'll be able to at least see what the content is.
I wasn't planning on removing the drum from the car, the bung is pretty serious so I can't see it leaking when the drum is next to new, it also can't be filled up past the bung anyway when on its side.
When filling jerry cans, its always recommended to put them on the ground, (due to static elec i think) So filling the drum, thats in the back of you're car, nope, would not do. Plus, as above, Its illegal.
Local servo actually has still shots of its camera's of some bloke filling a jerry in the back of his ute, and it catches alight, scary stuff!
From a quick google search, the total fuel you're allowed to carry with a car is 250l, including car's fuel tank, and It has to be mounted outside the car.
http://www.whatsupdownunder.com.au/News/Tips-Hints/Carrying-Extra-Fuel/Jerry-Cans-February-2015
No idea how accurate this is though.
This is funny, mainly because Ethanol/Methanol is the treatment for most moisture issues. There is no way moisture will ever be a problem in a sealed container, and even if by some chance you managed to pour a cup of water into the drum, or left the lid off in a rain storm, the ethanol would quickly absorb the moisture and get rid of it from your tank, rather than letting it sit and rust. That amount of water evenly distributed in the tank would barely change the tune, I doubt an AFR gauge would read the difference.
I have used 2 year old United fuel from a customers car, he was too worried to run it and wanted me to drain the tank for fresh fuel to tune with. I poured it straight into the Evo running 32psi, no issues. AFR's perfect, ethanol percentage within 1% of what they were originally. If you tried that with 98 you wouldn't get far, hence why I am so amused when this discussion pops up each few months.
I've been running straight e85 for over 7 years now, never changed back, never touched my fuel system, never used stabilisers either. The only down side I have noticed is less K's to a tank. Any other ethanol myth is generally false. I prefer not to run the ethanol content sensor at this stage because as GTSboy mentioned they can lead you up the garden path, and it's another sensor to fail affecting the tune.
Dan, if you need it I have my old E85 205L oil drum I never use anymore, it has a servo hose and nozzle fitted. If you are interested I can send a pic. I just use 20L's these days, but I have 4 United servos selling e85 within 5 K's now.
I'm on the phone with RTA as we speak rather than working of google searches, which I've also been doing :)
I've also seen the stuff about static, you simply need to earth yourself, the drum/nozzle etc. I'm also not going to be wearing synthetic clothing or holding my phone.
For $20, happy to throw it in, not a big deal.
Would be interested to see that drum. I've got a drum but your nozzle setup sounds interesting.
Just got off the phone.
I can LEGALLY have a FULL drum IN the car. Any more than a drum and it must be trailered, placarded with dangersou goods signage and you need a license but a single drum is LEGAL
Must be secured and he advised me about the risks of ignition and fuel vapors.
Windows will be down, will drive slower than usual, will employ ratchet straps.
This information is specific to NSW, I have no idea about other states.
The issue becomes if the service station will allow me to fill it in the back of the car, given once full I would not be able to lift it by myself.
Earthing shouldn't be an issue as I can just use an earthing lead from the drum to an earthing point in the car/to the pump.
Alternatively I may need to just borrow a bunch of jerry cans from my mates and fill those instead.
Edited by ActionDan
I got pulled up for filling a plastic Jerry in the back of ute. Two chances filling up a 44 in an SUV.
Interesting, I regularly fill up 4x jerry cans and my R33 shit box and no one has ever stopped me though?
Heavy vehicles have 1000+ litres in multiple tanks, including belly tanks under trailers with no placards etc. Also a lot of Earth moving companies use portable storage tanks in Utes without problems
as a earthmover that has a big arse truck I will say this is incorrect, my truck has only one 400l tank and it does have a placard and so does the excavator which is only 110l
Also contrary to popular belief diesel in not flammable, it is a combustible liquid so the same rules may not apply
Edit: if your desiel is flammable stop buying from that servo
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
