can i have your old injectors fpr and fuel rail pretty please
If I ever get rid of them.
If my stock fuel pressure regulator will support 440cc or 550cc injectors and allow me to get the full use out of them, of course I will keep the stock set up, but I did research and from what I found, it is recommended to upgrade the fuel pressure regulator.
So please anyone, if I don't need to change it, just let me know.
See. There's the problem. I bolded the problem. It's just absolutely not true. And if you did your research properly, you would have found very specific mentions, by me and others, on this very site, saying that you do not. Do you want me to do the search for you? Take me 30 seconds. Watch.
  • Like 1
I am asking one thing,
If you do not want to help please stay off of my post.
You are a hindrance.
I have learned much more about cars in the past time.
I have read many posts saying that the stock fuel pressure regulator is fine with 550 injectors and its about setting the mix and etc. Also I read that it is not good and that a FPR is needed.
I have read many articles and posts.
So I read many other forums other than SAU. Your country is not the only other country outside of Japan that has had rb's and skyline's for years. Even in the states they have been there.
So you can post all the links you want, if you want to help, good, thank you, if not please go away.
The internet has millions of pages of information, I am not going to find everything.
It seems many people have different thoughts on what needs to be done.
So I will read more and go from there.
If you really want to have a childish row, please take it and go else where.
No time to waste, got to keep moving.
If you want to help, I am listening.
I will check out my FPR I have now. Dont know if its running properly or not.
With me doing the hard run I did and my fuel pump starting to go out, there may be other parts of my car that needs to be fixed, replaced.
I will get one if needed.
http://www.tomeiusa.com/_2003web-catalogue/e135_fuel_regulator.html
Based on Tomei, they say it should be used.
They have an interest in you buying one don't they...
You don't need one. If your stock one is broken buy a new stock one.
End of thread.
Dose pipe ftw.
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
