I have a future project in mind that im very seriously looking into,
Now 99% of you will tune round and say this is a stupid idea but please look at it from my point of view.
Im hoping to convert a RS4 Stagea to Diesel Turbo,
Now this is where i know your asking WHY???
Yes i know it will be slower,
I travel 700+ks a week for work and get Diesel fuel for free,
I have a Nissan Avenir SW11 Diesel Turbo and its a great car but getting up over 300,000ks now and i want something a little better for towing the boat but something im happy to drive every day.
Im not out to win any races,
Before anyone asks the RD28T was in the Nissan Patrol/Safari and that is 300kgs heavier than a staega,
Now i under stand the requirements of an adapter plate and pickup. (think same thing as a RB30 GTR conversion)
So im certain i can get it in there and running,
The area im a little unsure of is the wiring, How much input from the engine ECU is required to make the Attessa AWD system work???
I believe it may need a signal from the throttle position sensor, Which i guess i could fab one onto the injector pump to get a sensor feed setup from that.
Is there anyone on here that knows how all the wiring etc for this system works that i could bounce some ideas off, (someone with an open mind who doesn't just think that the only way to modify a car is to make it faster).
Or someone who has some detailed wiring diagrams of the system that would be great,
I would in parts at a Auto Electrical work shop so have a reasonable idea how wiring works and have sparkys to bounce ideas off and help me out,
I really want to try make this work on the AWD platform as i think with the amount of ks i do and pulling the boat up wet boat ramps the AWD will be very handy,
If it becomes seemly impossible then i guess that a 2WD platform could be used which will still give me the large diesel wagon im after.
We get alot of 2WD Stages here in NZ, So finding one is easy.
__________________
  • Like 3
https://www.sau.com.au/forums/topic/464561-stagea-engine-conversion/
Great idea, anything is possible with enough determination. One would think a Nissan-to-Nissan transplant is easier than dropping in an engine from another manufacturer.
I've been following this LS1 thread where a member bought a VF GTS wreck and transplanted everything into a VF wagon shell in less than 12 months ... massive job and very well done, massive credit to the owner: http://www.ls1.com.au/forum/showthread.php?169220-VF-GTS-Wagon/
Good luck! Subscribing
I have a Stagea workshop manual (in Japanese) if you need wiring diagrams.
Have you got a S1 or S2? If S1 you will need the ecu to control the Auto.
The problem with AWD is you need the sump because it has the diff in it so is the diesel sump anywhere near the same as your RS4?
Whereabouts are you? Joe Kyle in Henderson has been adapting the diesel block to run (petrol turbo) in Skylines so may have some tips for you...(re engine mounts etc).
Excellent i will talk to Joe Kyle.
Im up in Northland, Project won't be a fast one, While my Avenir is still running strong there isn't much pressure. But im paying for the RD28T today so its not all just dreams,
If it is just a Tacho feed i should be able to steal that from the back of the clusters or directly off the back of the alternator or pump what ever the RD28T uses for a signal feed,
The TPS switch i was hoping to adapt to the back of the pump off the end of the cable drive,
Its just wiring in the TPS to the system that could be the problem as im unsure about where to do that,
Any diagrams would be great i'll PM you,
Just to recap:
ATTESA pin -> ECU pin - Description
Pin 3 -> Pin 5 - Tachometer signal
Pin 23 -> Pin 37 - TPS
Pin 34 -> Pin 43 - Sensor ground
You could just run your own length of multicore wire down to the passenger side panel in the boot and patch into the existing loom. Easy if youve already got everything pulled up to work on the fuel pump.
  • 4 weeks later...
  • 1 month later...
Just to let people know i wasn't another one of those peoples who just have big dreams but don't give things a go,
RD28T from a Y60 Nissan Patrol. Doing the timing, water pump, seals, rocker cover intake and exhaust gaskets, (rebuilt or upgraded turbo from Steve Murch)
103,000ks from a side impact damaged truck
Then next up is get the money together for a 2WD-4WD sump adapter and pick up from RIPS,
Car i picked up super cheap.
Series 2 Factory Manual 4WD Turbo 220,000ks.
Has badly blown head gasket, Extremely tidy other wise and has had RS260 interior fitted
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
