Hi Gents,
I've sold my daily to free up some money to pull the motor out of my R34 to give it a once over. I am just looking to get another set of eyes on the build to make sure i have all the bases covered.
My intention to be able to use the car on track days, as well as to maximise on labour while the motor is out.
I've highlighted my 3 concerns in RED, also interested as to anything else that is worth doing while the car's guts are out
Car is a '02 R34 GTR M-spec
Current set-up
Compression was 175 +/- 2 across all 6
Mileage: 105,000kms
Currently tuned to 267.9rwkw @ 16psi (front driveshaft removed to preserve the front diff) by MRC in Castle Hill.
Exhaust / Intake
- Amuse R1 Titan Extra cat-back exhaust 90mm
- Apexi Super Catalyzer Cat
- Mines Pro front pipe (2 x 70mm into 80mm)
- Tomei dump pipes
- Nismo inlet piping
- OEM Airbox with Nismo Snorkel
Ignition / Fuel
- Sard 650cc top-feed Injectors
- Splitfire coilpacks
- Wiring specialties coilpack harness
- Nismo 255L fuel pump
Engine / Turbo
- Garrett 14psi Actuators
- Stock Turbos
Proposed Worklist
Engine
Turbos
- Garrett -9s (purchased 2nd hand)
AFMs
- Nismo AFMs
Cams/Cam Gears
- Standard camshafts
- Jun Cam Gears (purchased 2nd hand)
Engine & Gearbox mounts
- Nismo mounts
Oil Management
- pretty much everything listed here, lol http://hioctaneracing.com/blog/2010/11/19/the-reality-of-the-rb26-oiling-system-part-2.html
- 9L Extended sump - Hi-Octane
- Oil/Air Seperator - Hi-Octane
- Rear cylinder head oil drain fitting - Hi-Octane
- Cam Cover Baffle - Hi-Octane
- Catch Can - Hi-Octane
- N1 Oil pump + Billet Oil pump Gears - Hi-Octane (is this combo the most suitable form my application? The next one up would be the Nitto Oil Pump)
Cooling
- PWR Radiator
- Is an oil cooler justified at this point? I was thinking about a setup from Golebys parts? - http://www.golebysparts.com.au/parts/browse/171/nissan-rb20-25-26/oil-cooler-kits
Block
- is it worth forking out the extra to forge the thing at this point? This is the area i know the least about
- Pistons
- Rods
- Rings
- Bearings
- Head Gasket
Gearbox/Diffs
- Overhaul Transmission and Rear Diff - incl. bearings, seals, gaskets, syncro rings (generally 1st 2nd and 3rd)
- performed at Award Gearbox and Diff services in Seven Hills, NSW - http://awarddiffgearboxservices.com.au/
Misc.
- Major service incl. N1 water pump
- ancillary belts
- New hoses/lines
Some of the threads i have been through and referenced;
http://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/
http://www.sau.com.au/forums/topic/364449-n1-oil-pump-into-rb26-to-prevent-big-bearing-problems/
http://www.sau.com.au/forums/topic/429930-1994-r32-gtr-stock-to-320kw/page-2
http://www.sau.com.au/forums/topic/419857-shopping-list-for-500hp-rb26/
http://www.sau.com.au/forums/topic/236467-definitive-guide-to-building-300-330awkw-gt-r/page-3?&&p=4275763&hl=definitive%20guide&fromsearch=1#entry4275763
http://www.gtrusablog.com/2010/05/real-basics-nissan-skyline-gt-r-r32-r33.html
Some pics to entertain the non-readers
Edited by squareznboxez
Dont let the nissan out!!
Leave the short motor alone unless you plan for something way bigger than -9s
Rear head drain bs isnt needed.
Have a vent from the sump welded in and plumb to the catch can
Yeah fair call man, my concern i suppose is the risk associated with leaving the whole thing in there while just replacing the turbos and wicking it up to 20psi, my fear is it will cost more when she decides to give out under load.
It's a fair bit of coin yeah, but whay makes you say it's a waste? I don't really plan on going bigger turbo-wise and i'd like to lean on the car for the odd track session/hill climb.
Although not cheap, it does seem cost effective to have it all done at the one time i would have thought.
Seems like a lot of money wasted on a -9 setup
Nice car! What is your power goal? Engine seems in good nick - I wouldn't bother pulling it out at this stage. People are making a lot more power than you currently have on an unopened engine. You don't mention ECU - I assume you have a Power FC.
Have a read of the oil control thread (or say the last half of it). Rear head drain is not. Octane don't mention a restrictor on the oil supply with an aftermarket oil pump.
If you are worried about thrashing it on the track make sure the cooling system is up to scratch. Invest in DataLogit for PFC and if your oil temps are getting too high get an oil cooler. Use a high quality synthetic oil and most important of all get a pointer to a really good tuner and don't cheap out there (BTW looks like you were on 4 wheel dyno - no need to remove the front drive shaft).
  • Like 1
Thanks mate, the HKS 2.8l step zero kit seems pretty sweet, it would add at least $3K in addition to forging the block though.
http://www.rhdjapan.com/hks-capacity-upgrade-kit-rb26dett-2-8l-step-zero-87-0-full-kit.html
Atleast put a stroker in it if you going to go through all the trouble of pulling it down
Thanks, i've read bits of fatz thread, but will sit down and digest both these threads
Look at fatz for inspiration on how much the stock motors can handle
Check simonR32's build in the Motorsport builds section. 2+ years at 700ish hp and a LOT of track work at 2bar
re: power goals
I'm looking to just make the most of the -9s as it will be predominantly street driven, i don't see myself moving up them them. It'd would be great to go down the flex-fuel path, but i see that as another investment for another time as i'll need ECU, injectors, fuel rail/pumps, sensors etc.
also yes car came with Power FC and the apexi boost control module
re: oil control and tuner
Yeah thanks i have bookmarked your page on the collars and restrictiors, I think for the cost of the golebys oil cooler, its worth doing. I've decided to go the Nitto oil pump instead of the N1 + Hi-Octane billet gears, car currently runs standard Redline 10w-40 (non-racing version)
It was MRC's preference to drop the front drive shaft, their feedback was as the front drive isn't full-time like Evos and WRXs, running it in 4WD can cause the front diff to burn out.
I have to say, that doesn't make the least little bit of sense. Someone is thinking at that problem with the wrong part of their brain.
Dont bother doing a rebuild, do do headgasket and upgraded head studs. Can lift a stock 26 head with 20 psi. Fit the oil restrictor on the block while the head is off.
The hi octane sump has a provision to attach a return line, make that a catch can vent, that seems to be a key in helping prevent oil blowby issues.
For what you want n1 pump should be plenty.
Do do the oil cooler, but I'd go for one with a thermostat. Also consider removing the water to oil cooler. You make find the golbeys one hard to fit with that length of hose, the popular greddy/hks ones mount below the passenger headlight as its got room and airflow.
Also do a quaife front diff while it's all apart, heck leave the gearbox till it gets worn if it's still good they are not that hard to remove. Rear diff wise don't bother rebuilding the a-lsd, get a proper mechanic one.
Apart from that, replace all consumable bits. Water lines (under the plenum) also get a good quality braided line kit for the turbo feeds. Do all relevant seals on the engine while you can get in there good.
  • Like 1
Thanks Pete, yeh i think i'll try track down a Greddy unit.
Good advice on the diffs, i will just continue using/servicing them as normal until they give out and then replace with mechanical units
Note, as the front diff is in the sump... which isn't removable unless you pull the entire engine out*, and given you need to strip the diff out of it to do the extension, its very advisable to do the front diff upgrade when you've got it apart. The rear, however, takes about 15 minutes to get out, hence my comment of doing it at a different time. Just bleed the A-LSD system if you feel its performance isn't up to it, any air in there really makes it play up i'm told.
Rear is a mechanical LSD - front is an open diff and it is possible to swap it for a Quaife LSD with the engine in place.
Hmm just checked and it may be that the M spec also has the V-Spec type computer controlled rear diff .
I thought an Mspec was a vspec with a few extra luxuries
Bingo.
OP, all this stuff for dash 9 turbos? Nah, keep the $ in your pocket until it blows up or going huge HP.
I have same turbos in mine on stock motor, it's still alive after 3 years and counting.
Yeah fair call, instead of forging the internals, the money seems better spent on the front diff. I still think there is value in pulling out the motor for a once-over for gaskets, seals and lines, as well as the oil control.
Regarding the front diff, what are the value-options out there, Kaaz, Quaife?
http://justjap.com/quaife-atb-helical-lsd-front-differential-nissan-skyline-r32-r33-r34-gt-r.html
http://www.sau.com.au/forums/topic/343375-anyone-using-a-quaife-diff/
Bingo.
From what i've gathered, the M-spec share the same platform as the V-spec 2 (larger 322mm rear rotors), but has;
- Ripple-control dampers - slightly quicker damping for more neutral handling (over the V-spec 1 & 2s bias for oversteer)
- Thicker rear stabilizer bar - combined with the shocks to balance the handling
- Heated leather seats
- Slightly different leather for the steering wheel
- 40kgs more than the base BNR34
http://www.sau.com.au/forums/topic/76852-various-r34-gtr-qs-m-spec-vs-v-spec-etc/
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
