Hey guys i have an r33 gtst which i am hoping to bring to around 230-240rwkw and keep lag minimal.
Current mods are:
10psi boost
Full 3 inch exhaust
Apexi pod filter
Blitz return flow cooler
Gtr fuel pump
Car is making 180atw
Upcoming mods:
Power fc
Bigger injectors
High flow turbo
Z32 afm
so my questions are.
1. Is it worth tracking down a r34 turbo to highflow over a r33 one? I heard the 34 can flow better but is it much laggier?
2. What size injectors should i be going for and any other mods needed to reach this power level.
3. Does anyone know a good tuner in melbourne, located in west suburbs but willing to travel.
Any help is very much appreciated im fairly new to skylines.
https://www.sau.com.au/forums/topic/465051-r33-gtst-a-few-questions/
You're in the right place.
21U Highflow and Adaptronic ECU from Hypergear in Somerton.
Injectors from Scotty.
Get it fitted up in Dandenong at Forced Motorworx and tuned by Trent @ Status Tuning in Keysborough.
The 21U R33 turbocharger is super responsive, that supports an average of 260rwkws on P98 fuel, 20psi @ 3500RPM.
The R34 turbocharger has an larger rear housing that is capable of making more power, handles more timing, we can also high flow it using our ceramic ball bearing system thats brings the optimum throttle response out of it. The turbocharger it self is capable of supporting the 270rwkws region in average, 20psi @ 3650RPM CBB or 3800RPM plain. If you have both turbos available, in my opinion OP6 is an better pick.
Pm sent
Thanks for all the info guys.
I will pm hypergear
Isn't 1000cc injectors overkill though? I was thinking i would only need around 555ccs
There's no point messing about with shitty old school injectors in the 550cc range. The modern Bosch ones will idle better than the crappy old ones even at twice the size. Plus then you will NEVER need to upgrade them, regardless of what you do (within reason).
  • Like 1
  • 3 weeks later...
Guys, I'm new to SAU, I'm actually buying a mates 33gts25t in roughly 3 weeks(cheers tax). I believe he's a member just not sure of his user name.
Anyway, I have a few questions seeing as this will be the second boosted car I've owned, first being a GT forester(let's not get into that) lol.
So basically we've done some minor mods and whatnot to it since I've been friends with him, and we aren't quite sure of the KW figure. Haven't been bothered to pay for a dyno.. Probably roughly 180-90ish
I know it's got the usual tasteful mods..
That being..
*Blitz Return Flow Front Mount
*3 inch cat back
*Walbro 255L pump(I believe)
*NGK Plugs
*Profec B2
Now when I get it I plan to go 3" turbo back.
Any tips or hints on how to get it around 220KW's without spending an arm or leg?
Any help would be greatly appreciated.
Cheers!
I was considering a Nistune.. Not sure what everyone's take is on them but I know they're roughly 500 brand new.
Well it will be sliding at some point, but casually not everyday.
i thought about a 2540 upgrade but I've heard some bad shit about them.
Contemplating going Bosch 500cc also.
Not sure on the AFM though.
Obvious place to point you for a turbo is Hypergear. Look at the Hypergear thread. All of it. The 21U highflow will do up towards 250rwkW. You will need the Nistune of course and it's a sensible choice. It's less easy on R33s but at least it's not as bad as it used to be. You should look into what it actually takes to achieve it (effort and cost wise) then decide if any of the other options make any sense to you (such as an old PFC, or an Adaptronic, to name a couple of options). You will need injectors to make the best use of the turbo. Likewise a Z32 AFM (if you stick with Nistune or PFC).
Already messaged Hypergear. I was going to hi-flow the T25, but on second thoughts seemed to be a waste of money as such.
I'm not sure why everyone leans towards a power fc these days.. Majority of the lads I know that have stageas or skylines always have the fc. What's the difference? Besides the obvious hand controller which gives you all the readings.
I'd prefer to spend less money on a Nistune because I'm not building a weapon that has no purpose of being road driven, as it can't be driven to its full potential, and well having a skyline with a reading of 600kws at a drift meet is pretty pointless, as long as it holds sideways then that's all that matters really.
Probably because Power FC are cheap these days and if you want to Nistune an R33 you have to find a suitable Z32 ecu and set up the VCT control (if applicable).
I don't see how a hg high flow is a waste of money. 250-260rwkw on 98 and 300-310 on e85 and full boost by 3.4-3.5k rpm for $850 and is a 100% bolt on affair, no spacers or other bull shit required. I don't believe you will find any other turbo in that price range and unless you are chasing massive HP its a no brainer for most. Hypergear also does excellent pricing on adaptronic ECU's if you buy a turbo from him. You won't require an AFM or boost controller with one of them either, they do all the fancy crap, flex fuel, wb input, launch control and the customer service and support from adaptronic is phenomenol. My 2c.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
