Got the turbo off without much trouble, i took lots of pics and wrote down the steps i took so i will probably post a diy for others once i finish.
I got the mamba braided line kit which included the turbo gaskets, nuts and studs. However the stock hardlines look fine and the waterline that goes from the top of the engine (just under rear of rocker covers) looks impossible to get to. I was thinking of just using the stock water lines or just swapping the easy waterhose with the braided one.
What is the benefit of braided lines if the stock ones are hardlines anyways?
Ok im tripping out right now. Started the car and took it for a short drive around the block to get it to operating temp, without hitting boost at all.
Now there is white steam like smoke coming from the turbo. Im hoping its just degreaser residue or coolant. None of the lines are leaking and i made sure to drip some oil into the turbo before starting the car.
Any ideas, im really hoping i havent stuffed this up :s
Looks like you're not using the stock boost controller. The line with the bolt in it looks like what used to be the bleed line. What sort of boost control are you using? I'll check back through the last 4  pages to see if you have mentioned it.
OK just read the whole thread and no mention. What are you using for boost control? i.e. what is connected to your actuator? Some kind of manual T ?
I was using a turbosmart boost t set to 10psi on the old turbo. the new wastegate actuator is 18psi but i had to leave the t on because i forgot to buy a vacuum line. Planning on getting an ebc though
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
