If Airbags Are Deployed Does This Mean The Car's A Write Off? Low Km's Accident
Was involved in a 4 car pile up last weekend.
My pride and joy which was only imported two months ago from Japan was beat up pretty bad but the accident was under 20 km's as far as I can remember as it's all blurry after the airbags went off.
1997 R33 GTST Skyline 40th Anniversary model automatic Midnight Purple, only 98,000kms on the clock.
I want to know if my car a salvageable....
Front was pushed in just touching the front of the timing case.
Engine didn't spill oil and transmission also fine.
Bonnet bent, pretty much front end damaged.
Car was towed away. .....awaiting report from insurance company to be assessed.
Csn I get it assessed? As I believe that it's repairable...
Both passenger doors open fine.
No rear damage, just bonnet and front end.
I'd post photos if I could here but haven't figured out how to yet...post-74120-0-22206400-1464557931_thumb.jpgpost-74120-0-81008400-1464557959_thumb.jpgpost-74120-0-26437200-1464558020_thumb.jpg
Edited by mercyseat
you can get it assessed but it still up to the insurance company to if they write off.
rule of thumb is if repairs are more than 75% of insured value they write it off.
from that i can see needs
lights
fog lights
bumper
bonnet
rad support
prob radiator
prob fans
all the plastics like under tray inner liners
new steering wheel
new dash
new airbags
paint
labour
i would not be holding breath for them to fix, it is a 20 year old car and OEM parts are getting hard to get
I wasn't tailgating anyone.
It's in dispute as to the car in front slammed his brakes on first hitting two cars in front of him first.
It's insured for $10000 agreed value.
I'm hoping if they write it off of possibly buying back the salvage if it's considered a repairable write off. The car's immaculate pre accident, good resale for parts possibly, who knows.
Will decide after I hear back from the assessor's in a few day's.
Just didn't know what airbags cost to replace.
I thought the definition of tailgating was too close behind to stop if the other person hits brakes..
curious who is your insurance with?
if you buy it back getting it back on the road is an expensive process as it will be deemed a write off.
you need to show receipts for all parts and work done to get it back, go through inspections, and even then most insurance companies will have nothing to do with it.
Or track it.....
And what if the person in front comes to a stop from hitting vehicle in front of them abruptly and doesn't hit the brakes?
"Tailgating is the act of driving on a road too close to the vehicle in front, such that the a distance between the two vehicles, does not guarantee that stopping to avoid collision is possible."
It would still be considered tailgating, that is the whole point. You should allow enough time to both react and stop.
I reckon it will be fixed.
Mat from nistune hit a car that pulled out from a side road, damage looked very similar. That was fixed, and he had a front mount that was smooshed also, having said that it wasn't his fault so that might come into play.
Normally...
Front Car is not at fault unless they did something malicious or downright stupid...
Middle Car is at fault for hitting Front car.
Back car is at fault for hitting Middle car.
Quite often they'll ask the Front car if they felt 1 hit or 2 hits.
If 1 hit, the collision order was Back->Middle, then Middle was pushed into Front.
If 2 hits, the collision order was Middle->Front, then Back->Middle.
Either way, Back car is normally found at fault... the only difference is if the Middle Car is also considered at fault (aka. Did they stop in time)
I'm with a reputable insurer. There's no problems there.
As to who's fault, probably more than one person's fault but me being the last car will/have copped it. Still in shock from the damage done seemingly i actually stopped less than 100 metres prior to let the car i ran into , in front out of the side street. So from stop to accident within 100 metres is fairly unfortunate. As mentioned i blacked out and only remember the airbag going off in my face.
Was just too wet, people rubber necking the car broken down on the side lane...etc etc.
For me the car's sentimental more than money is worth. My last 1994 R33 was car jacked in Sydney back in 2004. So I'd waited over 10 years to buy another one. I'd only imported this car less than two months ago....pretty bummed out about the whole shit-suation.
Regardless I've lost $$ .
I doubt I'll buy another one knowing they're a write off at 20 km's once the airbags are deployed.
Its just the reality of owning a 20yo car. Even when they are in top shape, insurance companies wont care and will write them off after small-ish accidents.
My car took a hit in the rear quarter panel, needed an arm and probably the rear quarter. Was insured for 30k and it was written off with Shannons.
I would say you are absolutely written off there.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
