Hi guys. I want to build my skyline into a reliable track/street car. It is not my daily, but I still want it to be as reliable as possible.
At the moment it has a 3" turbo back exhaust, spitfire coil packs, hks coilovers, return flow fmic and a ebc running 10psi and upgraded radiator with a gktech fan.
I run Penrite Racing 10w-40 10 tenths engine oil and change every 5,000km.
I have heard some issues with the rb25 is the oil pump, needs a crank collar. Can this be done without removing the crankshaft from the engine, pretty sure you have to machine it though.
Oil restrictors I have heard from research on here are essential too as well as a head drain kit and rb26 rocker covers.
What else should I look at doing to make it a reliable package. Also is this stuff required if my plan is to go to 250rwkw running a Link G4+ with a Kinguawa low mount turbo?
Thanks guys, please leave details and no sarcasm.
https://www.sau.com.au/forums/topic/465659-building-a-reliable-r33-skyline/
None of that is required. Fit your ecu, bigger injectors and turbo, retune and enjoy. 250rwkw is a walk in the park for an rb25. You'll need a better fuel pump if you don't already have one. Walbro 255 for that sort of power will be fine.
A mate of mine blew his engine from a failed oil pump at the track because he was on the limiter for a couple seconds. His was a neo seems like its a common issue, of course can keep it off the limiter but it happens sometimes
A mate of mine blew his engine from a failed oil pump at the track because he was on the limiter for a couple seconds. His was a neo seems like its a common issue, of course can keep it off the limiter but it happens sometimes.
I'll change that to none of that is required if you stay off the limiter.
Raise rpm limit to 10k. Lol. Honestly man there's heaps of unopened rb25's out there pushing above 300rwkw doing hard track work and surviving for years. If you want to pull an engine apart to fit a crank collar and oil pump, go right ahead, you may as well put some forged pistons and rods in it and then you can go out and test how much limiter it will take before it goes bang. Then you can tell us how many seconds it took so everyone knows the limit :)
Not sure if the RB25 shares parts with the 26, but my car showed up with 5 destroyed main bearings from what was no doubt oil starvation. BUT the thing I want to add here is that mine also had 2 cracked valve guides. They are brittle and crack. I would change them for bronze and get the head overhauled in a heartbeat if you are pulling the head off.
If speaking of reliability.
No need to open the engine for 250kw. Use a quality synthetic oil and a quality tuner.
If you want to bash the limiter go right ahead and wait till it blows. Then pull engine and spend the $10K - $20K to make it stronger.
  • Like 1
Bragging rights.
370kW here, has about 27psi into it and used for track. Usually run about 23 to 25psi on the track. Motor has 350000km+ still going strong. Just pushes a bit of coolant after 10 hard laps at 27psi. Seems ok about 23 to 25psi, all it has are ARP non 2000 studs.
250kW is a walk in the park.
  • Like 1
Well that kinda sucks. Tracking being a drift event or circuit?
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
