Hello
I found this info someone put up about different Nissan diffs.
Is this correct? http://www.nissansilvia.com/forums/index.php?showtopic=337751
I have learned from other places that having a 4.3 or 4.1 ratio diff is good to get for a rwd turbo car.  Is this a good ratio to have?
Edited by yoshiii335
https://www.sau.com.au/forums/topic/466150-questions-about-diffs/
Have you got an R32 RB20DE? If so you will have a 4.1 diff already (4.111 non abs or 4.083 if you have abs.
There is no such thing as a good ratio. There is only fit for purpose. What do you want to do that you can't already?
No, just checking.   Learned that 4.3 is good followed by 4.1 and some people put 4.1 on their turbo cars.
If the diff ratio I have is good already, than I want change.
That really doesn't answer the question mate.
You've obviously sat down and thought about the potential gains of a diff ratio change. What are you hoping to gain?
For what's it's worth, put a RB25 NEO in it and enjoy life.
What I learned is that cars with a 4.3 or 4.1 diffs are good. I learned that sometimes non turbo cars have those diff ratios to help it along.
I learned that 4.3 or 4.1 diffs are good to have in turbo cars.
I wasnt sure what mine is.   I am putting a Nismo LSD in mine.   I know my car is over 25 years old and the diff is most likely not working  correctly so I will put in the Nismo.
I change the diff oil once a year to help keep the diff working as well as it can.
Well......what you learnt is not true.
For drag racing, sure, go for a short diff ratio.  But turbos really like tall diff ratios so you can load the engine up in each gear and get a bigger run in each gear.
My R32 had the obligatory 4.3 diff in it.  When I did the RB25 transplant I put a 4.11 into it, and if I could have found a good way to do a 3.9 I would have.  3.7 was an option but would perhaps be a bit too tall.
And your diff oil does not need to be changed every year.  And you especially do not need to be putting LSD compatible oil in it (just in case you are) because your stock diff will be a viscous piece of poo and does not work like a normal LSD.
I want to have everything to help me with my acceleration as much as possible, non engine parts.
Ok, little confused, you said what I learned was wrong, but you mentioned that 4.1 is what you had and you wanted to go 3.9.  Yes I understand that 3.9, etc is good.  I wasnt saying that the shorter gears are better. Just what I learned about 4.3 and 4.1.
So you didnt like your 4.3?   Would it be worth it to put in a 4.1?  My engine later I am looking at is going to be a 25 or 26.  Why couldnt you do a 3.9?
4.3 is really short.  For a pissy little engine like an RB20 that's good.  For a bigger, torquier engine like an RB25, higher gears are better.  Hence going to the 4.11 that the R33/4s had.  There wasn't a readily available 3.9 gearset available when I was building my Frankendiff, so I just used the 4.11s.
I'm sure the RB25 would pull 3.7s.  It's doing nearly 3000rpm on the highway in 5th, it could certainly use longer legs.
Is it a pain to change to a 33/34 diff? Many things have to change?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
