1 hour ago, welshy_32ZILA said:
Yes  1:1. How can't it be 1:1? 36psi on intake ~36psi in exhaust manifold. If emap was lower we cld push more boost till the emap rises all depends on where the tuner wants the ratio between map:emap.
Sorry what I meant by saying "it can't be" (when referring to 1:1)  was that that is really very good and not an indicator to me that the Turbine housing is a restriction.     Sounds to me then like its probably pretty good to drive!  :)
  • Like 1
5 minutes ago, usmair said:
what the heck is an emap
Exhaust manifold pressure.   When talking about turbocharged spark injected cars 1:1 boost versus exhaust pressure at full power was pretty much the realms of drag car setups not a really long time ago, I have had conversations with people who actually have doubted it is possible to have equal exhaust pressure to intake pressure so managing to have a reasonable amount of response while not having boost pressure go past intake pressure is quite a big deal - albeit still meaning it is leaving a heap on the table.
 An EFR8374 making this much power with a 1.05 would have a scary amount higher exhaust pressure than boost pressure - if it was possible to even do it
  • Like 1
I guess it depends on where u class map:emap your stopping point. Ie in my instance that's where we stopped and class it as a restriction. Obviously a few things could help the power figure. Better head/cam setup and trial of the 1.45 rear along with not having leaking tbs also.
I would suggest that limiting boost so as not to exceed 1:1 E/I MAP ratio is being far far far too conservative. it is not that long ago that a street turbo car would have 2 or 3 :1 ratio.
I would lean on it some more. Even a1.5:1 is absolutely free breathing in real terms.
  • Like 1
That's a tricky one, though.  For the compressor to push air it needs force at the turbine to accelerate the turbine&compressor and move the air (which has a mass) - let alone to compress it.   That force comes from drive pressure, which is essentially the raw EMAP value you are reading.  If you do headwork to require the amount of boost pressure required to move x-amount of air it will reduce the amount of work the turbine needs to do to a degree, meaning a bit less drive pressure required - but the trick there is you have reduced numbers from both sides of the ratio.... so your EMAP reduces, but so does your IMAP and you COULD even find yourself making less power as a result of the reduced boost you have to run to keep the ratio at or below 1:1.
It's a bit hard to say which will reduce more, but if I were a betting man I'd be backing the cost vs reward benefit as not being anywhere near as rewarding as just using the turbine speed as the primary warning for overwork, and maybe relaxing your EMAP/IMAP ratio cut off back to even about 130% (which is still quite conservative imho) you will get much better gains than the headwork for no cost or compromise.
Just my opinion, but it's become a conversation so I'm throwing it in there.  If you were happy with the current power level then thats all good, but if you are looking at spending a bunch more money to try and get more performance when the data suggests the performance is available comfortably with the current package - I'm not sure why you'd not use the obvious approach.   As @GTSBoy said - 1:1 is crazy conservative for most cases, and is more of what you'd see in they higher levels of drag racing where you have something you are looking to make MAX power so reducing forces and restriction is the priority, response is absolutely not.
Edited by Lithium
  • Like 2
I don't think the head is a major restriction as your setup is pretty similar to mine - my head is not ported and has baby drop in cams with basic springs/retainers.
It just means you need more boost to make the power.
Did JEM tune your car?
Nah mate Sean from what used to be EFI. He's now at Auto Care Centre in goldy
On 10/15/2019 at 5:49 PM, welshy_32ZILA said:
Yea running a kulig kit. I'm not too phased on the dyno number to be honest burn. Last time I rolled off the dyno with 460hp I was surprising people with nearly the same in kw.
I totally missed the fact you were bleeding off a lot of boost up top.
I saw a post with 8474, 2.6l, 36psi and 500kw and thought it didn't add up. now I've seen the dyno sheet it makes a lot more sense.
Carry on!
Edited by burn4005
  • Thanks 1
Carry on!
Yeah it’s make sense. It only about 25psi at higher rpm. My one make similar HP on 25psi. But I got 1.45a/r housing, different engine setup and different dyno(awd).  At the end I set at 26psi 710awhp. And it is still more room for more hp if I use 4 ports boost solenoid.  For drivetrain safety I don’t want push more.  I think 1.45 will help and it doesn’t take too much response away.
Look closely. My one made 700hp is between 7500-8000rpm at 26psi.
Welsh’s 2.6 peak power at 7300 around 30psi.
I think the head setup make some difference.
the 8474 1.45a/r on road feeling is better response than my old 3582 gen2 0.83a/r.  And go faster for sure.
  • Like 2
This is a good comparison as mine was also done on The pits Dyno. 8374 2.6 1.05ar.
490kw run was 190kpa (27.5psi) and I was limiting turbo speed as the 8374 was at 126k rpm, hence it nosing over.
Edited by burn4005
that's perfect comparison. so RB2.8 8474 1.45 made 525awkw on 26 psi 117krpm. 8374 1.05 made 490kw on 27psi 126krpm.  and if same engine same a/r housing  the response should be very similar.
is that rwkw or awkw?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
