I think the biggest difference was made by the pads, of course the rotors and ducts would've helped a bit. If you're not regularly tracking I wouldn't bother with braided lines if your stock lines are in good nick. If you have to replace because they look suspect then definitely worth it. My 2c[emoji4]
Glad I could help :)
Check out adms15' video on how his SR pads performed at Sandown.. pretty damn good!
They're no Project Mu HC800 pads but they're close enough and at half the price, it's perfect for a weekend track warrior
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sr[emoji106]
  • Like 2
  • 3 weeks later...
So I've decided to install the pads and discs myself after looking at guides.
Is the caliper bolts torque spec the same for gtr as gtst? Guide says 92-118nm
On 10/10/2016 at 8:23 PM, admS15 said:
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sremoji106.png
I got sent Intima SR instead of SS, they're great, Needs a couple of hits for it to warm up but perfectly driveable on the street (slow, daily driving). Once they're warm, holy shit they stop. Overkill for daily duties but works. Not that dusty either (especially compared to A1RM).
  • Like 2
So managed fronts yesterday. Drivers side was stuck but improvised with a clamp to get the disc off.
Tried the rears this arvo. Rear left easy.
Rear right is stuck and giving me no love. So I'll prob need to get some bolts to screw into the two holes do you guys know the specs on what I'll have to buy?
Yes use the bolts but also bash the drums all round with a big hammer to loosen things up (assuming handbrake is not binding). You may need to clean up a bit of a lip inside the drums before you put them back (unless you have new ones).
thanks guys ended up finding a couple of spare bolts from my top feed rail that fit the holes.  Managed all four discs and pads over the last couple of days, rain, darkness and the one stuck disc made it more than a day, as well as taking my time on the first one. but overall pretty easy job.
Thanks for your advice and esp thanks to Johnny and STT
  • Like 1
  • 4 weeks later...
On 03/10/2016 at 0:44 AM, admS15 said:
The car is a R33 gtst, stock sumitomo calipers, plain rda 324mm rotors with adaptors up front and rda slotted/drilled standard sized rears with sr pads all round, penrite 10 tenths fluid and stock brake lines. Small 35mm agi pipe ducts run from front bar to back of discs on front.
How are you finding the RDA's on the track Bill, any issues with the heat? Have you run DBA's before, for comparison?
I'm getting an annoying squeal (yes have added copper grease) and some shudder on the front right and trying to diagnose the cause, someone suggested the classic 'warped rotor' but will need to investigate further. My current DBA T3's have been skimmed once, there's maybe one more skim left in them, but in case I need to replacement I'm wondering if RDA's would do the job for ~60% of the price...?
Hi Jussi, so far so good but they've only really copped 1 hard track day. I need to put them through some more torture before I can give a decent assessment of how they cope under extreme duress. Haven't had dba before, just Nissan oem which held up well over multiple track days. I'll keep you posted in the future.@V28VX37
  • Like 1
On 10/3/2016 at 10:23 AM, MatthewT85 said:
Thats good to hear!, looks like the bigger disc/cooling ducts are making a big diff,
Yeah I had my Brakes go dead after 3 laps at Symmons. Im not chasing lap times, but just want something reliable.
Do you guys think its worth swapping to braided lines as im redoing pads and discs?
I think the theory with braided lines is the same as M/C stoppers: more instant reaction when you hit the brake pedal i.e. no initial flex of the bulkhead or expansion of the rubber brake lines.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
