VH41DET r32
Hi,
I've spent the afternoon searching the forums for info on a vh 41 conversion into an r32.
I've found lots of topics on people doing it in racecars, or people talking about doing it but never posting the finished product.
I'm just wondering if anyone has done it in a street car and if there are  any businesses experienced in doing it? It's something i'm very interested in but the quotes i've gotten locally are insane because no one has done it before.
Just hoping someone can point me in the right direction.
Thanks!
https://www.sau.com.au/forums/topic/467026-vh41det-r32/
There's a few around and its pretty straightforward - the bell housings are available over here and no doubt in Aus as well. If you're going to pay someone to do it it will cost an arm and a leg. But why bother? An RB30 makes much more sense..
This is an R33 but its much the same:
http://www.trademe.co.nz/motors/used-cars/nissan/auction-1163792991.htm
and this is an R32 but  VK56
http://www.trademe.co.nz/motors/used-cars/nissan/auction-1166480588.htm
  • Like 2
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779666
Search through the N/A section.  There's a VH45 conversion owned/run by Captain Natro, who (I think) is maybe from the Toowoomba area also.
If it had to be a Nissan V8, go VK56.  Cubes count.
On that front, go LS.  7 litres of goodness.
If you want to keep sanity, as per Bob's suggestion go RB30DET.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779670
1 hour ago, Malek41 said:
Search up mcmtv2 on YouTube and they do a vh41 swap in a stagea. Very very detailed so hopefully that should help
Complete with turbo - a great job but they are not willing to put a dollar amount on it - would probably be north of $100,000! - although AWD added to the complexity.
Here's the video - there's  about 12 episodes I think:
  • Like 1
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779704
Only issue is I want it turbo and engineered all I have to keep low capacity.
Yeah I've watched all of them but I figured that rwd would have to be much more straightforward.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779795
I just had a look at captain natro, he is in Toowoomba, I know how car. Pretty sure it's got an ls though.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779798
OK, let me put it another way.  You want more cubes.  VH41 is old old old tech, common era with RBs pretty much.  VQ is the new hotness.  Provides most of the "more cubes" you could get from the VH but with a whole lot more modernity, more compact dimensions, ease of making exhaust manifolds and turbo locations and blah blah blah.  Lovely 6 speed gearbags available.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779877
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
