You can get the manual for the R32 GTR and it outlines the complete gearbox reabuild and all tools required. It is something I would like to try and do myself too but; as well as transfer case rebuild.
  • 1 month later...
You need a decent sized press to press main and cluster shafts out at the same time. And you need to brace the centre plate as they can break. Other than that they are easy
  • 4 weeks later...
Went looking for this in the manual but couldn't find it. What page is it on? I'm probably blind, sorry for the amateur question.
Cheers.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
