Car stalling while driving with new turbo
hi all,
i just replaced my turbo on my gtt from factory turbo to Garrett gt 30/76 internals on my factory housing.
when i drive at a rpm over 3k and put it in neutral the revs will go all the way down till the engine stops.
does anyone have any idea why this could be ?
thank you
factory pipe work.. could be leak somewhere..
Are you running any wanky BOV? or is everything stock except the turbo?
Also it might be overboosting because the turbo has a larger actuator on it.. not ECU related.
2 hours ago, miskyline94 said:
It's a factory bov but it is blocked of to re-curc and I have a front mount intercooler other than that its stock
there's your problem :)
The pressure is also going through the air flow meter backwards. The ecu sees this as additional air flow and injects more fuel. On some cars with air flow meters this causes stalling problems on others just rich running, unless the ecu has been tuned for it. Try unblocking and see what happens. Im sure dosepipe will correct me if im wrong :banana:
  • Like 1
Also i might add,
the reason i changed the turbo is because the factory one shit itself but when it went out there was a bit of oil around the intake hoses, so i was wondering if some of that oil would have gotten on the AFM.
should i remove it and clean it with contact cleaner? @admS15 @Dose Pipe Sutututu
ok so i there is nothing the bov is doing to the stalling,
but we did rasie the idle a tad so the car has stopped stalling and also must of fixed the over boosting problem.
a new ECU is defs on my list but money wise it is not going to happen very soon.
and whats a nistune board? easy install and pricey? @GTSBoy
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
