  • Replies 76
On 17/12/2016 at 1:37 PM, R33gtst2016 said:
Or is it not a gasket just sealant ?
do not ever use sealant, you'll end up in a sad financial mess if you do.
OEM seal or OEM seal those are your options.
Note the S14 and S15 seal fits too on your R33 R34
So I've f**ked up along the way somewhere I changed it over I thought all went well, but won't start, cranks over but doesn't start tonight after work I gotta take it back out and double check my wiring were right positive to positive n negative to negative, there's a dash light on but I dno what it is
That tells you when your Cat Coverter is blocked (there is a temp probe in the Cat that sets off the light at a certain temp)
Could it be a Cat problem? If that is coming up when you are trying to crank I doubt it. I'd only expect it to come up after the car is driven for a bit
Are you hearing the pump run? If no it may be a wiring issue. I remember remarking at how brittle/fragile some of the fuel pump wiring was, maybe something has broken with those. If you are hearing the pump run I would pull the whole assembly back out and make sure everything is installed as it should be.
I would confirm you are hearing the pump first. Then, if you are, pull the fuel line going to the fuel rail off and try to crank it and see how strong of a stream you have (you may want to just test for pressure).
If those tests "fail" then I would pull the pump out and inspect everything.
Not sure if its the same on R32's but on my R33 if i turn the key about halfway between on and start and hold it there the fuel pump runs. Did so with Power FC anyway and the Link does it to however cuts the pump after a few seconds
What would happened when I try to start the car if I didn't put the hoses on correctly? I've checked I can defiantly hear the pump, but still won't start just cranks, thought that I've put everything back the way it was originally but don't understand why won't start. Any ideas
Maybe you have the inlet and outlet hoses crossed? On the 32s that space is tight and they could easily get crossed. Easiest way to check is to pull fuel line going to rail and reroute it into a bucket. If you can crank it and fuel comes out, you know they are plumbed correctly.
Also, what condition is your fuel filter in? A clogged filter could give you grief as well.
If you took the hoses off at the pump and aren't getting any flow, the issue is in the tank. If the pump was working correctly you'd have fuel everywhere.
To answer your last question, you want to focus on the hose between the filter and the rail, removing it from where it connects to the rail.
But start at the tank, it sounds like your pump isn't pumping.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
