Hi everyone
I'm shopping around for 6mm hub centric (66.1) wheels spacers 4x114.3 . I've found a place who will make them for $90 but I want to find a cheaper price. There's a lot of non - hub centric spacers around for a lot less.
Know of any good deals?
https://www.sau.com.au/forums/topic/467588-wheel-spacers/
you wont buy hub centric spacers that thin, 10mm will be the thinnest you will get, and as @niZmO_Man said GKTech. At the end of the day they will set you back $100 for the set off 4. Stud centric spacers are cheap for a reason. They are illegal and more dangerous.
Edited by Coullsy
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789136
23 hours ago, R-sanichi said:
Hi everyone
2 hours ago, R-sanichi said:
@Nizmo_man I tried GKTech. They only sell 10mm and thinker.
Hi I had mine made at a local engineering shop, 2 6m spacers $40, hope this easy solution helps, Jamind
Edited by jamind
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789208
OK but GK Tech 10mm are probably the best you can do off the shelf (although you will need longer studs). If you can get 4 made for $90 that is the same as Jaminds $40 for 2.
http://www.gktech.com/index.php/4-5x114-3-10mm-hub-centric-slip-on-spacers.html
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789309
This whole conversation is hurting my head.  For a start, we're looking for a cheaper price than $90 for 4x spacers.  Are these being used on an R31?  Because only R31 owners are that busted arse broke that $90 seems like you should be searching for a cheaper price.
Then there's the thought that you can even make a 6mm spacer that will correctly locate on the hub centre behind it AND provide an equivalent hub lip on the front side.....the chances of which are pretty much f**k all anyway.
Then we have the thought that, "no matter, I'll just carry on as if I hadn't been told that" and keep seeing if there is a way to get them made in New f**king Zealand, and then pay for them to be shipped to Australia, and still expect them to be less than the $90 price obtained locally.
Oh.  My.  f**king. God!
  • Like 3
https://www.sau.com.au/forums/topic/467588-wheel-spacers/#findComment-7789322
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
