New Comer from Bangladesh/UK
Hi All
I was participating in the forums from 2013-14 during my postgraduate studies. Back then started with R34 GTT and then replaced with a R33 GTR.
Last month migrated to AUS, based in Melbourne, VIC. Imported a '94 R32 GTR with a lot of Nismo goodies. (Will post separate thread about it later)
My goals for the Forum are as follows:
-meet some car enthusiasts
-source spare parts/accessories/etc
-seek advise on maintenance/tuning/troubleshoot
-gain further knowledge of R and S platforms
A bit about myself:
-Studied Automotive Engineering in UK
-Worked at GM and Jaguar Land Rover in UK
-Currently seeking engineering opportunities in AUS
Look forward to meeting some people in future meets.
  • Like 1
https://www.sau.com.au/forums/topic/467734-new-comer-from-bangladeshuk/
  • 2 months later...
Hi Guys
Here are the pictures of my R32 GTR landed in VIC.
The car comes with heaps of Nismo N1 Genuine Parts, seems like the previous owner in Japan basically made it identical to the N1 car.
Very straight body and probably had a respray in Japan at some point (hinting from the gloss paint finish) and a super tidy interior.
Please let me know your thoughts!
  • Like 4
Hi Guys
Sadly I think I have to let this go because of unemployment for the time being. Before selling, I'd like to keep the LMgt4 Wheels, Steering WHeel and Weldina Exhaust, as hopefully I will get another R32 when I am financially more stable.
I already got a set of R33 GTR wheels which is on the car right now. But need to find a set of Steering Wheel/Boss Kit or OEM Steering Wheel, plus an exhaust system.
Please let me know if any of you have these for sale?
  • 1 year later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
