21 minutes ago, Coullsy said:
That's a fantastic idea, definitely a lot safer and more controlled then the PIT, but the non tethered style is a bit questionable
Why do you think its questionable? Just dangerous, causing a rear wheel lock?
3 hours ago, Coullsy said:
At high speed, a single wheel lock with an inexperienced driver, the chances of the car spearing off into other traffic would be quite high
What about an inexperienced driver being in a PIT maneuver.
4 minutes ago, Coullsy said:
This is true
That said, the ole PIT maneuver is not that common in AUS I don't think. Police round here tend to give up on chases before anybody gets hurt. I'm not an expert enough to have an opinion on what is the better approach. :ermm:
Quote
I think here in VIC there was talk of abandoning pursuits all together as a matter of safety. There was a bit of an uproar at the time, so I don't know if it was actually happened...
From memory there were a couple of serious incidents (crashes) that involved innocent 3rd parties so VicPol were looking to minimise this chance.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
