  • 2 years later...
Funny how life happens and projects get the back burner and then the fire gets lit.
I now have a Cast forward Facing plenum and lq9 coil packs. I got the car to fire but it ran terribly. Would idle around 13.5 afr then go to 11.5-10.5 and choke. Swapped around coils and even got some known working ones off a friends r32 which seemed to help but I wasn’t convinced the igniter wasn’t bad or Ecu was the issue. Since I’m running all aftermarket parts figured spark upgrade was needed.
I also found a mess with how the shop build by the original owner of the swap had made of the harness and wiring. I wish we had skylines in junk yards here because the loom may need replacing.
Edited by Zrbsliding
If you have a spark issue wideband will go lean.
Good info, one would think the lack of spark but still having fuel would make it go rich. Car has nistune but I’m not convinced the ecu isn’t damaged from sitting for 6 years out in the elements from condensation. We get a lot of rain here.
It is counter intuitive, but not having combustion take place means there is heaps of o2 left over, rather than most of it being used up from the burning of fuel. I’m sure someone can explain that better!
j
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
