SKYLINE WONT START ! HELP !!
So hear me out first guys, hear the full story it might help !!
i changed my Blitz Pod filter to a K&N one
Car was running fine, and on my way back home I decided to give it abit in the tunnels, after giving it all the sudden my car started choking or chugging and I thought my engine died, but it was still running, it runs fine till I step on the pedal half way it chugs and struggles and pretty much wont let me Go over 3,000 RPM so I thought maybe it's the POD that's acting up the AFM cause it felt like it was the case.
So the next day I changed it back to the Blitz that I originally had earlier on and went to drive it around and it was back to normal "woooooooo" and as I got close to home it did it again the chugging and choking like it was gonna die, so I was f.. could it be my spark plug or coils.
So the next day I changed my Spark Plug, it was a BKR5EIX-11 which isn't recommended but I had it laying around so I replaced it, my old spark plug was black and burnt on the tip so I thought yeah maybe this should do the trick!
Plug everything back in and....
it CRANKS AND STARTS FOR A SPLIT SECOND AND immediately dies out and I only have one conclusion left, the Coilpacks but I want to see what you guys think
-every hose is plugged in correctly and tightly
-strange thing is that before I change the spark plug the car was running but a weak start up so I thought Spark plug but now I don't even know anymore.
PLEASE HELP ME GUYS !! Could it be the coilpacks ?? Could the spark plug have anything to do with it, even if it's not recommended it should still start up, it's gapped at 1.1 which is how the plugs came (Bkr5eix-11)
https://www.sau.com.au/forums/topic/467861-skyline-wont-start-help/
I replaced it with bkr5eix11 cause I had it sitting in my rooms for years for my NA/R34 which was recommended. And nah doesn't seem like a fuel issue, I got half a tank and I can definitely hear the fuel pump just before starting the car
From what we can tell the only thing changed was the filter, I would look at the Maf extensively to check for damage.
My car would not start and sputtered going into boost when the plugs were fouled. Also check for ground wire to coil packs/ignitor.
Have you considered that it could coincidentally be an alternator or battery that is no good? It's a big leap, but you should probably just check how many volts you have on the battery terminals before and during cranking.
33 minutes ago, Jonic said:
The ecu is stock and fuel line is good, I think it's the AFM since I change the Pod around and maybe it bounce around too much and played up perhaps
Well just unplug it and see if it starts.
LOL so I tried starting her up after work and guess what, it started weak and actually stayed on, Tried it again 10mins later and wallah it's starting up and running all good again ! Haha what a confusing moment, what in the world happen ??
Now everything it out back together the car runs but the PROBLEM OF THE LIMP MODE IS STILL THERE !! I can't even rev pass 2000rpm, even when parked! Something must be playing up and I'm thinking it's the AIR FLOW METER. Ever since I changed the Pod Filter the problem started, but the thing is I changed it back to normal but it's still limping, I can't even hit 60Kms on the road :0
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
